marcelnl
- Sep 13, 2009
that just might be the problem...on the PCb pin 13 and 14 are connnected to ground (0 Volt) you need to disconnect them from the ground and connect them to 3.3 volt.
If you so not disconnect you short 3.3V to ground.....you either have to disconnect Pin 13 and 14 on the PCB from ground by scratching through some connetions OR you unsolder pin 13 and 14 and lift them off the PCB.
