Axelrod1
- Mar 8, 2004
I think the biggest problem with the highs comes when the high-end on the cd is so drastically off level from the mids and lows. actually, it's probably mostly a poorly mixed low-end, low-volume, etc.
when you can't feel the lows enough (acoustic bass for example) and you want more, you're first reaction is to turn it up -- which causes the normal/correct highs (trumpet) to destroy your eardrums... after getting good headphones, the words "digitally remastered" means alot more. I can completely hear the difference in most of these older recordings.
plus, these headphones sound GREAT with dvd's.
so. I guess I'll have to buy remastered CD's or just self-EQ on the bad ones...
obviously, the highes are brighter than some other phones, but I think I still like them overall to deal with it.
-Ax1
-Ax1
