Thank you very much indeed, brilliant! On (i) I have headphones of around 30 ohms, any guidance on hi/lo?
Use low gain for 30 ohms headphones.
With the lo vs hi gain... Try the lo first, raise up the volume, and if it's too weak at full volume, then change to hi. Just make sure to only change gains when the VV is off.
Thinking of getting one of these. When it comes to ipods is it only compatible eith ipod classic 6th gen or 7th gen as well?
V-MODA VAMP VERZA Device Compatibility
Mac (OS X v10.5 Leopard or later)
iPhone 3GS
iPhone 4
iPhone 4S
iPhone 5
iPhone 5s
iPhone 5c
iPod Classic 160gb (2009)
iPod Touch 4th generation
iPod Nano 6th generation
iPad 1st generation
iPad 2
iPad 3rd generation
iPad 4th generation
iPad Mini
Thanks. Pardon my noobness on this, but why isn't the 7th gen supported as well? What changed between the 6th and 7th?
I placed an order for a 7th Gen yesterday, but only made up my mind today that I'd like a Verza, so have ordered a 6th gen too. I'll have to refuse delivery of the 7th gen.
So finally received my Verza over the weekend. Only got round to using it today with my iPod classic and WOW!!!
Played he first two Hybrid albums back to back to 'break it in'. Using my Westone 4R and the first thing I noticed was how much the bass tightened up. Vocals sound as clear as ever too.
What I most impressed with though were the orchestral segments. They sound more lively and it's almost as if you sat right in the middle of an orchestra.
So far I'm loving my purchase and can't wait to hook up my M100.
I do have one issue though. I am using the supplied USB - 30 pin connector with my ipod classic. I have the verza set to iAmp and Vamp. The ipod battery seems to be draining a lot quicker than usual today. I would have thought I would be getting even more out the ipod battery as I am bypassing the DAC right?
Any ideas?
