Craigster75
- Apr 21, 2012
I never thought I would say this, but I completely agree with money4me247. I think it is more than a stretch to believe the color of the earpads has ANY effect on the sound assuming the same materials are used and they have had the same break-in period which goes back to materials, not color. Although, I did shut off my lights last night while in the middle of a song and the sound signature of my M-100 completely changed
I personally am extremely, extremely skeptical that someone would be able to hear the difference in sound between black ink & white ink of the earpads. I would imagine that such a minute change in sound between two headphones can probably be attributed to the unavoidable standard variation due manufacturing process.
It's a bit like paint, when different color absorbed light and age differently, and this will in turn change the maternal in question over time. Of course the difference is very slight, but it is there and detectable.
Actually, it's pretty easy to tell the difference. For example, I had the black m80s for a while and picked up a set of whites for my wife. Her pads were quite a bit softer and broken in out of the box and you definitely could get a better seal with them right away without having to warm the pads up with your ear heat (lol, that sounded funny). So there actually is a difference and even my untrained ears noticed it. This was on the M80s where the pads are smaller too, so the variance should have been even less noticeable, but then again, it's on ear versus over ear, so the seal might just be easier to notice the difference.
I confirm dbdynsty25's findings. I've got both the shadow V80s with black earpads and white M80s with gray earpads. The gray earpads are softer than the black. The gray pads isolate a little better for me when I first put them on -- this is pretty obvious from listening to ambient sounds with the headphones off. Slightly more isolation means a slightly stronger seal, which should translate to a slightly different sound.
How much different, and whether it is noticeable is probably listener-dependent. Also, heat changes softness, so over time, the two might behave differently. I'm not planning on experimenting on it, however.
To bring it back on topic, I find it fascinating that Val notices the very slight difference in the sound of different pads. I would not have thought of this without his mentioning it. It is another sign of V-MODA's attention to detail.
So I shouldn't worry about getting the black pads, after of continuous and heat they should sound the same as the grey and white ones right?
More or less, and I don't notice any major difference between the shadow and white that I got.
