Craigster75
- Apr 21, 2012
on the M-100???
Well there are people that seem to be using them on just about everything else lol (like Pro900 in the sig thread)
Joking but I'd like to see if it can be done
I'd also recommend always pulling from the bottom of the pad, since there isn't a clip at the bottom-most point of the earcup. When removing one of my XL pads from the top, I managed to rip the pad halfway off its plastic base.I was luckily able to do some advanced surgery and salvage it, but that was a "FUUUUUUUUU--" moment, to be sure...
I don't believe there is a way to make it work.
some pages back (might be quite alot of pages actually), right before the XLs were released, there was someone who used a 3d printer to create a thingymabob that clipped onto the cup instead of pads, and had wide "wings" that allowed for attaching whatever pads you wanted. i think he was using some sort of akg pads, cant remember...
now that the XLs are released i feel this may be superfluous, but it will definitely work =]
ey adamlr, that was me. The pads I first tried with the adaptor changed the sound too dramatically I think. I was going to try with different pads, not velour but leather ones and something closer to the hexagon-eliptical shape of the original ones, but didn't do it beacause the XL pads solved the problem quite nicely.
heard these are good for bass, but does that make the mids and highs a blur behind the thumping? or do they still have presence and clarity?
(on a side note, does anyone know if the headband on the shadow model is difficult to keep clean due to it being fabric and not leather? because the shadow model is £60 cheaper on amazon in the uk and is very tempting, as is the white model)
is the sound changed?
though the xls are pretty good , attaching say, beyer velour pads to the m-100 sounds pretty dreamy... im curious to know about the sound changes if you can bothered. oh and what pads did you use? was it akg something?
Edit: would the in-line mic on the standard cable be passable for console gaming with an Astro Mixamp? I was going to get a boompro but they are 4-6 week wait time on the vmoda site. I wouldn't be using it very often anyway
