Zombie_X
The main purpose of this was to save some money as I didn't want o buy another HP amp. I figured speaker outputs on receivers/amps would have more than enough power to drive headphones.
As most of you know, speaker outputs on receivers/amps put out more power than the headphone outs on amps. The headamp section is usually very limited in power, while speaker outs are quite a bit higher in the power/current area. This sparked an idea in my head. Would it be possible to use headphones on the speaker out's of an amp? So I made a DIY connector to do just that. Initially I was worried that the increased power would blow my headphones drivers, and in that thought I pulled out my Ibuds to test it with.
I put the cable I made into my Sansui amp. Surprisingly they worked with no distortion, but a ton of hiss. Now that I know it will work I just went up the chain to a higher impedance headphone. I plugged in one of my HD600's and was blown away. My Sansui drove them nicely, and the hiss was almost completely gone (I think it was cause the headphone was higher impedance). The finaly test was to see it if could power my 600ohm DT880 and it did! The volume knob was not even halfway and they were very loud (well over 100db!!
Using the 600ohm DT880 through the headphone out was a pain since they didn't get loud enough nor did they sound good. Then I put the adapter into my Fischer and was bowled over again! Man the speaker outs make a HUGE difference in sound quality/dynamics! The Fischer could now drive the 600ohm DT880's whiel before they were quiet.
So what started out as an experiment turned out to be the best thing I have ever done. I was not expecting the headphone's to work out of the speaker out. Now I will never use the HP output again on my Sansui/Fischer amps.
I would definitely say try this if you can. I would suggest using a cheaper HP when testing since you may blow them if the output is too powerful.
