Originally Posted by cobaltmute /img/forum/go_quote.gif
I'd re-read that link. the clean supply is the USB and the bad one is the external.
hehe, we're playing w/ words here
he said that the interface w/ the external PSU was worse than the plain USB power....when you see the internal cheapo SMPS within the Musiland 02US, it's pretty obvious that it'll be much worse than a quality ATX PSU and that it will pollute the case w/ massive EMI.
but saying that the USB power is clean is just not true, and you know it
you get all the 5V ripple from the ATX SMPS(120 mV maximum by the ATX standard on the 5V rail), and the very dirty ground that's polluted to death by all the other computer components...and when some components(CPU/GPU/HDD) are under heavy load, the ground is even more dirty as this is where they flush...reason why many ppl get ground loops reacting to the graphic card's activity.
all the audioholics will say that a SMPS is just a terrible idea for audio, and even worse if it's shared w/ tons of noisy computer parts.
a random link discussing the issue:
Do SMPS have a home at high end audio? - diyAudio
and a random link w/ ppl(including the main head-fi admin) discussing how much of a difference a clean PSU makes:
http://www.head-fi.org/forums/f21/fi...pplier-410199/
using a computer 5V supply to feed a DAC stage is totally fool to me...there, I said it. now prove me wrong, by all means.
and a guy going nuts w/ ground loops over firewire:
FireWire 4-wire cable to break "ground loop" - mLAN Forums
Building a PSU for an external firewire soundcard - diyAudio
The firewire optical isolator is basically optical isolation for firewire device. So there is no ground loop flowing between your soundcard and the PC (PC ground is extremely dirty). |
sharing the audio ground w/ the computer will automatically lead to SQ degradation, why bother w/ USB when we have S/PDIF...that offers full galvanic isolation right off the bat?
USB power brings high ripple/harmonics and dirty grounding...how is that good to anything for audio? digitis? yes, that's the main source
