Magsy
- Nov 9, 2004
hehe, the hard part
I spent ageeeeeeees looking for a solution because my case does not have a removable lid.
I bought some motherboard style 'posts' which had thin threads on the bottom and were long. I drilled two holes in the bottom of the case and put a nut on the bottom of the post. My case has two 'grooves' cut in the bottom of it, the nuts fit in this groove perfectly so the case has no protrusions. The board is then fixed to the top of the posts.
I'll take some pics later to show you..
THe problem i have is the usb connector is a little loose on the pcb, I couldn't get it mounted firmly.
