So last night I decided to change cables around a bit. Not sure why I didn't try this before. Usually I try everything. I only had one good USB cable. The Audioquest Carbon. I had that feeding the Regen. And the cheap 6" after the Regen. I decided to reverse them. It was a HUGE improvement. Everything was incredibly more dynamic. Instrument separation is razor sharp. Super taut and fast bass. I thought it was great before but wow it was like I got a new DAC. The power and effortlessness was incredible.
It's strange because when I first got the Carbon with no Regen it's a nice rounded improvement. Same thing with putting it before the Regen compared to typical USB wires. Just a nice rounded improvement. But now putting it after the Regen it's a massive improvement. (and the jitterbug is still the first piece in the chain)
Late last night I had to go and order another Audiquest carbon to use before the Regen so I have a carbon wire on both ends now (should be here tomorrow). I gotta tell you that is an impressive USB cable too. Wish I could pull the trigger on the all silver Diamond cable. But I can't bring myself to do it. And I have to say these modded nuforce reference amps are ridiculously fast and powerful. I don't think any other amps compare to their dynamics and power. I think I'm really seeing them shine like they should without being held back by how bad stock USB is.
Just one more piece to add to the chain. The Ifi ipower. Which is still out of stock everywhere fore some reason in the states. After that I'll have almost $550 in just my USB implementation. Which is crazy thinking I was skeptical and reluctant to just buy my original Carbon wire when I started looking into USB. Now I feel it's the best money spent. Although now I wonder why I'm using USB at all and maybe just didn't pick up an optical cable instead and maybe bypassed all the bad USB issues altogether. Now I wonder if I would have had this great sound from the start had I done that instead, and for a lot cheaper. Could it had been better just using optical?
Wait,what DAC are you using here and you are hearing better sound placing a longer USB cord between Regen and DAC?
Should be better sound with a shorter cord between Regen and DAC.
BTW, AQ Diamond is worth listening to once or twice, just so you have a reference point.
