chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
Did you listen to one in person? Are you rack mounting these? If yes, I think Weiss comes in rack mount.
"Emm Labs Dac2xv2 and Headamp GSX will leave your setup in the dust. The level of difference is one you simply cannot even comprehend.
low end -> entry level -> mid-fi -> hi-fi -> high end -> ultra high end.
Your setup is at low end...maybe entry level. There is nothing wrong with low end/entry level gear. Some people simply cannot hear the difference or don't care."
Too many low end/budget fi pretending to be mid fi at this price point, I would chase down a used Sonic Frontier SFD-2 dac or Ayre USB dac or their CDP at this price point. There are many other choices I just haven't spent much time at this price point TBH.Any combos that can bring me to the mid to hi fi level and beyond for up to 1k? Specifically a combo that pairs excellent with the HD 800s?
They are pretty excited about the Weiss DAC501:
Later in the video they say that the 502 is just wider. But I see a XLR 4pin port also on the 502. If thats the only difference I am going for the small one.
There was a used 502 on Agon for $6500. Should have gotten that and forget about DAC for a decade. I think right around that $10k MSRP price, Weiss, Meitner, Linn and MSB would be my top picks. Weiss is probably the bargain at $10k with integrated streamer, digital EQ and bunch of other stuff.I do now know how your thread went from $2500 to $4500 and now you are talking about Weiss 501/502 which is way over $4500
Anyway, if it is with your budget, I will give the Weiss DAC my highest recommendation.
Just get it and forget about the rest.
And there is a newer 4ch version of Weiss 501/502.
What about a Chord Mojo 2?Holy cow Sonic Frontier SFD-2 dac is still 2-3k range. I'm hoping for a reasonable mid to higher tear amp/dac setup for up to 1k. I suppose at that price point such a thing cannot be found?
Be patient. I have seen them go for $1k range. The good news is that this will delay your FOMO for a long time because any upgrade will likely be prohibitively expensive to you ($5k+ min) that you will have no choice but to settle down and enjoy your gearHoly cow Sonic Frontier SFD-2 dac is still 2-3k range. I'm hoping for a reasonable mid to higher tear amp/dac setup for up to 1k. I suppose at that price point such a thing cannot be found?
Good portable solution and can be a desktop replacement in a pinch. Chord's kilobucks solution is decent if you only buy new.What about a Chord Mojo 2?
