Guzomx
Is anybody trying the free refurbishment campaign?
Anybody knows if is legit?
I’m sending my multiverse Mentor and Mest Mkll.
My multiverse and Mest suffer of socket problem. The cable unplug very easy. Is really annoying.I did contact them and it sounds 'legit'.
However, I'm in the 'if it's not broke, no need to tweak it' category. So have held off. My main issue is driver flex in one IEM on the MEST III which annoying but unfortunately difficult if not impossible to rectify.
Some of the cables are loose on my mest2 too but some are not. Perhaps just the 2pin thickness or some 2pins are a little pinched together?My multiverse and Mest suffer of socket problem. The cable unplug very easy. Is really annoying.
I am between MEST MKII and MKIII, Is it really worth spending the extra money for the MKIII?
i think im just going to get the MKII it is literally $750 cheaper on Musiktek. Ill listen at CANJAM NYC to both and if the difference does not wow me ill use my brain and ave the money for a FiiO M11 PlusIf you already own MkII, my personal opinion, it isn't a worthy "upgrade" unless you have free spare money. They are more like sidegrades to each other between MkI II and III. Just different flavor and preferences. I didn't hear the MkIII directly but I was listening to UM Mest Indigo (limited) that I thought was an upgrade to MkI or II, but not really even having more drivers, which later reborn as Mest MkIII with exact driver config, tuning and even shells. Mids are more slightly refine though but differences are subtle.
I had the M11 plus (ESS). If youre treblehead, you'll be pleased with mest + M11 plus ESS combo but if not, you may feel they are too bright or too treble forward since Mests have forwarded trebles especially in 6-8khz and M11 plus tend to be a neutral with hint of bright, good Soundstage though.i think im just going to get the MKII it is literally $750 cheaper on Musiktek. Ill listen at CANJAM NYC to both and if the difference does not wow me ill use my brain and ave the money for a FiiO M11 Plus
I read the MEST MKIII brought the treble down big time, maybe it is worth the extra price thenI had the M11 plus (ESS). If youre treblehead, you'll be pleased with mest + M11 plus ESS combo but if not, you may feel they are too bright or too treble forward since Mests have forwarded trebles especially in 6-8khz and M11 plus tend to be a neutral with hint of bright, good Soundstage though.
Well you're coming to canjam anyway just listen to both. It's really personal matter about taste up until here. Like I said before they're more like sidegrades to each other,I read the MEST MKIII brought the treble down big time, maybe it is worth the extra price then
I've tried the Mest 3 and it is definitely more refined, especially in the treble region. Less peaky treble but because of that, it is less fun and aggressive than the Mest 2 that I own. If you find the Mest 2 too aggressive then go for the Mest 3.I read the MEST MKIII brought the treble down big time, maybe it is worth the extra price then
How do you all find the imaging on these sets?I've tried the Mest 3 and it is definitely more refined, especially in the treble region. Less peaky treble but because of that, it is less fun and aggressive than the Mest 2 that I own. If you find the Mest 2 too aggressive then go for the Mest 3.
(Can always brain burn in or try different sources for the peaky treble anyways haha)
Thanks sounds great- the MESTii’s universals can be had for <$1000 USD these days. It’s probably one of the best deals in audio.Imaging with all Mests are among the best in IEM world. No questionable. The Mest 1 that I still keeping is the sharpest, but again with sligghhtt worse timbre (sounding more electronic than natural, imagine of grand piano sound out from keyboard), not that bad but noticeable.
Yeah It is, even compared to several big boys that priced twice or thrice, if we talk about imaging, Mests still hold up against.Thanks sounds great- the MESTii’s universals can be had for <$1000 USD these days. It’s probably one of the best deals in audio.
