Hey guys! So, I need a bit of help, and advice regarding this new hobby of IEM. I come from a mainstream audio background, as everyone who started their IEM journey, I usually use my over the ear Bose QC35, and has been my main listening gear for the past 3 years, and I enjoyed them. Simple and easy, also had a pair of "high end" skullcandy if that is a thing jaja, and Bose earphones (white and black cable). Well I just purchased OG UM MEST, and bought the FiiO BTR5 amp/dac bluetooth. Decided to start high end to experience all the marvelous thing everyone is saying.
It's been over a week since I got them and started listening to them. > 20 hours listening.
I need advice -
The thing is, I usually listen my music with the SkullCandies and QC35 at high volume to enjoy bass, and never had an issue ie. ringing ears and so forth. I love my electronic music, my trance, lounge, hard rock, metal, OG 90's rap, and modern rap. All music with lots of bass, I decided to go with the MEST because it ticked all the boxes with these genres the DD and Bone Conduction. But also of course, Jazz, Classical, Classical Guitar, Chill Out Café lounge. which is enabled with the electrostatic and BA drivers.
First impressions was the clarity and detail, stock silicone tips are rubbish, the comply foam tips are great. But here's the thing, to get the same level of volume to really enjoy the bass and overall sound I cannot handle the music volume with the MEST, it's too loud! The instruments sound very in your face, too "revealing", I find myself not quite enjoying the experience, even Jazz or Classical I have to listen at very low volume, and hence cannot really enjoy the full experience because of this. If I turn the volume higher in order to really experience depth, instrumental spatial orientation, bass, and soforth I end up with ringing ears! This is starting to frustate me, I feel with the foam tips, there is too much pressure! And with the silicone tips bass is lacking and the music shines, too bright.
I usually listen to music 4-12 hours daily depending on work load, and multiple things. But as all you guys, I love music. And I find myself getting real tired after 2-3 hours with the MEST, there is too much pressure in the ear canal, even at low listening levels. Why is this? And I'm sorry to compare an ultra high IEM with QC35 mainstream, but with the QC35 I could listen to music all day!
So what I did to reset my tinnitus, I stopped listening to music for two days. Then did the experiment, listen to all my genres with QC35 almost max volume and nothing, all good, enjoyed the bass and ended up with no tinnitus. Of course I know that IEM is almost - well with universals not that much - in the ear membrane and thus pressure gradients are higher, and greater with full seal such as the large comply foam tip (which I use, because it enable that sweet sub-bass rumble), but to really experience this bass and enjoy basshead music, volumes are too high, and I'm finding myself not enjoying these tracks due to the low volume I listen to, to not damage my hearing.
So listening to electronic music, rap I cannot really taste and enjoy bass or normal hearing sound because I'm almost forced to not exceed certain DB's to not hurt my ears.
So am I doing something wrong here? Are my ears destined for mainstream headphones jajaja JK.
But really, what am I doing wrong, am I using the wrong eartips? I just turn off all EQ, both the EQ from Spotify and the EQ from the FiiO BTR5, and turned only one or the other EQ and all the same (regarding volumes - not tonality).
I use APTX-HD with Spotify highest quality which is 320 kbps - and some FLAC files in my computer both connected directly or bluetooth.
I know that all this questions are from an amateur, but I really want to learn, I want to get to enjoy music as it was intended. But I need a bit guidance.
Thanks all so much,
Rizzoli
I'm guessing you prefer quantity over quality, nothing wrong with that! I also love bass and with the time I started to value more quality bass over quantity especially with my Home Theatre system when I started I loved when my apartment rumble, now not that much I prefer a tight deep bass that the boomy bass, I thing with the time you will get the same impression, maybe?
I remember try these Skull-bones extra bass THAT BASS WAS MOVING MY HEAD xD Too much but fun!
I suggest get a portable dac/amp with extra bass switch like the Fiio Q1 mark 2 or Q3, I have the Q1 and the extra bass is great!
You can EQ also and the Fiio BTR5 have different EQ profile I believe the Rock has more bass.
