The Ultrasone Pro 900 are some of the hardest hitting headphones ever made, flagship or otherwise, and that is only brought up further through additional amping. Do note I'm just talking about amping, I'm not even talking about adding bass boost to them. If you're looking for both bass quantity AND quality, these headphones should be near or at the top of your list.
Do keep in mind that the Pro 900 are already bass emphasized headphones, which means that not all bass boosts available will actually improve on what the hardware already does. I certainly wouldn't recommend you using a FiiO E5 or E6 (too weak of amps and severely mismatched with the headphones in question), nor the E7 (too dry presentation that only hurts the slighly bright headphones signature). The E11 could be a good match since it leans towards a warmer sound, and the E17 is bound to be a good match as well. A very popular headphone bass amplifier, the digiZoid ZO2, that works wonders with many headphones, does not match properly with the Pro 900. So basically, some research is required for gear pairing.
