Fonglol
- Aug 25, 2010
Wow thanks a lot Jibbie, just pulled the trigger and bought the 900's from buyauthorized, impatiently waiting now...
I actually Un-Kees modded mine, and I'll have to say I like it better. For some reason, the highs seemed really bright when comparing to my T50RP, so I took everything out, and the highs got back in line. Strange huh? Overall though, I think I'll pass up on modding my headphones now. I'll just be satisfied with whatever stock has to bring me.
Quote:I wonder what a silver balanced cable would do with these. Probably get it to an unreal level of speed and detail!I am getting into making cables and such, so if I get the Pro 900s, I will probably try that, along with a good balanced amp like the Ibasso PB1 or PB2. Good to know that the Blue Dragon is a nice upgrade. Haloxt maintains that even a cheap copper cables that is a larger gauge than stock, such as 20 or 22 gauge, unchokes the bass and opens up the sound.
That's exactly what I'm hearing now with this cable. They seemed so open and detailed stock anyway, but with the new cable the bass is definitely cleaner, and reaches a bit lower at the same time-- when switching back to the stock cable bass seems more congested and thick, while not having the same reach. That was quite a surprise. The overall sound just got more open overall though, with a bit more space and separation. The stage definitely widened too. I'd say that, along with the better quality bass, are the biggest changes I've noticed so far and the cable only has about 10 hours or so on it at this point.
And what are you waiting for on the purchase? ....If you get them?.. don't you mean when??
Quote:I actually Un-Kees modded mine, and I'll have to say I like it better. For some reason, the highs seemed really bright when comparing to my T50RP, so I took everything out, and the highs got back in line. Strange huh? Overall though, I think I'll pass up on modding my headphones now. I'll just be satisfied with whatever stock has to bring me.
I agree and did the same thing. The Kees mod dampened the bass some but squashed the soundstage at the same time, mainly due to the cotton fabric floating out back. It hit me that the cups and to a lesser degree the baffle vibrate like hell, especially when powerful lower mids and bass is playing. I have experimented with damping the central flat circular portion of the cups with a thin layer of blutack in addition to a thick bead of it wrapped around the edge of the driver and against the baffle. Wow, what a difference. The bass is much less overpowering in certain musical passages and I believe the imaging is now much more accurate. No damage to the soundstage as I can still enjoy the sound of the room in which a recording was made.
I did some a-b ing listening to modern classical chamber music with my K601s, which I believed to have a superior soundstage, to find that although the K601's stage is larger, it somehow seems too diffuse and airy, like listening to music outside when it can be harder to place each instrument in it's place, instead of a suitably sized room where everything appears in it's right place, which is how the Pro900s now sound to me.
It's taken a while and a few false starts to begin really enjoying these cans. When the thought occurred to me, it seemed so obvious that the cups needed some mass loading to settle down the vibrations. Try putting your fingertips to the cups when listening to thumping music at reasonable levels and you'll see what I mean. I think that blutack is an excellent damping material as it provides mass loading at the same time as damping reflections within the cups. One day I'll get around to trying some other audiophile-approved self adhesive damping sheets, but until then these cans are tops. I highly recommend that the tweak-minded try this simple mod. I'd be interested to hear results if anyone tries it out.
Piano sounds awesome on these cans, which is a great bonus when I primarily bought them for listening to metal in isolation.
A bit off topic but has any of the PRO 900 owners experienced XB500? The more I read about it the more interesting it gets.
For $50 shipped it seems like an even better bargain than M50 and I may have to pick one up just for the heck of it.
Nice collection! So would like to divulge your experience with both?
Quote:Nice collection! So would like to divulge your experience with both?
Let's just say, if you own the PRO 900, you DO NOT need the XB500. Mine has been "collecting dust" for ages now, but I did pull it out at one time to compare it to the PRO 900. The result? Well, the XB500's bass is a super unrefined, flabby version of the PRO 900. The mids and the highs are completely drowned out as well, so any type of music sounds really bad. If you EQ the heck out of it, it becomes a decent headphone, but still one that I would never buy again.
Guys I need your advice, something quite frustrating happened today.
I've been disappointed with the midrange for a while so I thought perhaps I should undo the kees mod, so while I was unscrewing the shield, one of the screws slid across the shield and landed on the driver as it was attracted by it's magnet. I got the screw out but it let a small dent on the driver. Since, I kees modded them, I think I voided the warranty, is that true or is there anything I can do to claim warranty. They still sound fine, I think, I haven't listened a lot to them since, cause I've been really sad about it...
I could try to remove the mod, but it would probably leave marks and they'll be able to tell or not?
