Modifiedz
- Sep 25, 2009
It helps if you get a real good prefect bend on the memory wire, and try to store it without bending the wires any, so next time they will be ready and require no re-fit. I only use my IE-40 at home, and made a pouch for them that hangs off the table, and when im done I just set them in the pouch with the wires hanging down and the memory wire never moves any. Having the memory wire stay perfectly shaped to hold the IEM just the way I like it is the most important to comfort, to me.
