UD-10 USB Audio Converter
Nov 11, 2006 at 1:30 AM Post #31 of 240
Originally Posted by Dept_of_Alchemy
It always amuses me that the Transit can be had for $90 and the next level up is the transports from Empirical Audio and starting at $600. All I want is a device that can take USB signals and turn it into SPDIF, without all the built-in-DAC nonsense...
I totally hear you on this!! Drives me crazy.
I'm hopeful that the 0404 USB is a good solution:
http://www.creative.com/products/pro...&product=15167
Externally powered, can pass 24/96, and is hopefully bit perfect. I did hear that it may be a resource hog. Man if its not one thing, its something else!!
-Jim
Nov 11, 2006 at 6:25 AM Post #32 of 240
I want an external device that runs on firewire, uses an external power source, can output AES/EBU as well as S/pdif and can be clock sync'ed (word clock in/out). Is that too much to ask?
The AES16 fulfills all of my conditions except the external bit :/ sigh.
Nov 20, 2006 at 5:01 PM Post #33 of 240
Originally Posted by agile_one /img/forum/go_quote.gif
Just ordered one, Miguel.
Hopefully it will arrive before our FL meet on 12/2, and we can give it a good listen there. I'll report back in this thread when it arrives.
Originally Posted by mrarroyo /img/forum/go_quote.gif
Look forward to it! Thanks.
Got my Trend UD-10 USB Converter from BuYoYo.com. Very good service - ordered late Saturday 11/11, and it arrived in Florida Thurs, 11/16 - excellent service from Hong Kong.
The device is exactly as pictured and described, and performs beautifully. I do not have the battery pack for it (ordered separately a few days ago), so only used with USB power so far. It does just what I wanted/needed. Gives me a nice, clean digital out from my laptop full of flac music files. Using foobar 2000 as player, and sending the output from the Trend UD-10 to a Stello SA220 dac via AES balanced digital IC, the result rivals mid to upper level cdp's. I liken the sound to the Cary 306/200 I had - very clean and detailed, and just a tad forward. I attribute none of the sound to the UD-10 - it is totaly transparent, which is what it should be.
I am happy so far. No snaps, crackles, or dropouts of any kind. Build quality is very good - a sturdy metal box, good quality connections, and thoughtful inclusion of a USB cable and mini x RCA connector to allow analog out from the headphone jack (which I have not tried). Looking forward to getting the external power supply. I will have this at the SoFL meet on 12/2 for others to see and hear, so more impressions will follow.
Nov 20, 2006 at 8:33 PM Post #35 of 240
Originally Posted by educator /img/forum/go_quote.gif
Have you tried to use ASIO with it?
No, not yet, but that is top of my list. No time yet to fool with the various ASIO drivers/hacks to figure out best way with foobar. It shows up now as a DS USB device.
Just got an hour or so in of quick listening from the Stello DA220 to an Audio Technica HA2002 amp and W2002 phones. So happy just listening that I left tweaking for later.
Nov 21, 2006 at 1:21 AM Post #37 of 240
Yeah ... just got asio4all up and running with foobar 2000 (0.9.4.1) tonight, and while I am still tweaking buffers and other settings, it is working just fine.
Originally Posted by Dept_of_Alchemy /img/forum/go_quote.gif
Yeah, is the pass-thru bit-perfect?
Should be. I can't prove it yet, though. Will see what is involved in trying to measure (doesn't foobar have a plug in that can check? -- I'll snoop around), and report back.
So far, still very pleased with this little box. Has everything I want, and nothing I don't want.
Nov 21, 2006 at 3:18 PM Post #39 of 240
Did some headphone listening last night, but only with Grado SR60, and only with the UD-10 under USB power, as I do not have the battery pack for it yet.
What I heard was good, very good. SR60s never sounded better - clean, clear, as much soundstage as possible for them - a nice view into the music. But while the UD-10 provided great sound quality, it lacked somewhat in quantity. There was plenty of volume available for my purposes of monitoring, and relaxed listening, but, at least under USB power, not enough for truly rocking out to heavy rock or metal. I would classify the headphone output as more of an analog out then an amplifier out.
Did not try high imp cans, but will get to it eventually - probably after the battery pack is here so I can measure the effect of that as well.
Nov 23, 2006 at 4:19 AM Post #40 of 240
High impedance headphone report.
Well, the battery pack is still not here (P.O. tried to deliver, but no one home to sign), so still do not know if it will give more output power than USB.
As a typical impatient Head-Fi'er, I yanked the balanced cables off my HD650s, reinstalled the stock cable, and have been listening to the USB powered UD-10 from foobar with ASIO drivers for the last hour or so.
Even more than with the low impedance Grados, highest volume is not what one would want for rockin' out or even listening to classical pieces with great dynamic range. Very pleasant for casual listening or monitoring, but most will feel the need for an additional amp in the rig for long term use. This reinforces my conclusion that the UD-10 is a way to get signals out of a computer (digital in any form - balanced AES, SPDIF via coax, bnc, or toslink optical, and analog from the 1/8" mini socket), rather than a headphone amplifier.
Once again, though, the quality of the sound is outstanding. Pure, clean, detailed, and coming at you from a deep, dark, bottomless hole of silence.
For me, the UD-10 is a definite keeper.
Nov 23, 2006 at 4:35 AM Post #42 of 240
I wonder how low the volume output is. I know I listen quiter than most. Could you compare how it performs against any entry level amp (from memory at least?). Also, wonder if it would be enough volume for IEMs.
Thanks
Nov 23, 2006 at 5:06 AM Post #43 of 240
Thanks
It sould easily overpower any iem I've ever heard, with the possible exception of ety 4s.
Against entry level amps (pint, Corda HeadFive, LD, etc), the quality is greater, but the quantity (ultimate loudness, at least with USB only power) is less. Of course, it's an apple to oranges comparison - can the Headfive, LD, or pint give a digital out from a usb in? No, and that (the digital out from a usb in) is what the UD-10 is all about, and why I decided to try it, and have decided to keep it. The outstanding quality of the analog out, and it's ability to drive headphones to pleasant listening levels is just a terrific and unexpected bonus.
If you just want a headphone amp, perhaps the UD-10 is not what you are looking for, but stay tuned for results after I get the external power pack. If you want quality digital output from a computer via a USB port, then I can heartily recommend it.
Nov 23, 2006 at 5:14 AM Post #44 of 240
Against entry level amps (pint, Corda HeadFive, LD, etc), the quality is greater, but the quantity (ultimate loudness, at least with USB only power) is less. Of course, it's an apple to oranges comparison - can the Headfive, LD, or pint give a digital out from a usb in? No, and that (the digital out from a usb in) is what the UD-10 is all about, and why I decided to try it, and have decided to keep it. The outstanding quality of the analog out, and it's ability to drive headphones to pleasant listening levels is just a terrific and enexpected bonus.
Hey, thanks. Looking forwards to keep on track. I didn't understand well though, when you wrote the quality is greater than those amps, and then you mention the digital capabilities. Speaking strictly about sound quality from the headphone out, you considered it to be better than those amps (headfive, etc.)? I suppose there's going to be some variation in sound (whether volume or quality) when using external power (both batteries and ac adapter). Now what would be interesting is how it compares against other usb dac and soundcards (Bithead, fast track usb, emu 0404, etc.). For the price it surely looks tempting.
Nov 28, 2006 at 11:19 PM Post #45 of 240
The above quoted posts are just so all my listening comments are in one place to make it a bit easier to follow.
The battery pack arrived just before Thanksgiving holiday, but with company and all, no chance to give it a try until tonight. Results? Sorry to say, no discernable increase in volume with headphones, so it appears it is just an alternate power source to prevent a laptop battery from running down when used without AC power available.
Sound quality is still excellent, but volume remains the same as reported above. HD650 is powered to moderate listening levels, Grado SR60 or HF1 quite a bit higher, and totally usable. I have no iems, but expect most would be very adequately powered. I am listening with HF1s right now, and the result is very satisfying - plenty of volume, and a clean, punchy, typically Grado sound.
So, is the UD-10 a headphone amplifier? I say no. It is a good headphone source for casual listening or quick monitoring, however. It's real strength and purpose is to get a quality digital signal from a computer via USB, and it does that eminently well. I am definitely keeping mine.
Look for more comments as others get to try it at Saturday's (12/2/2006) SoFL meet. I will have it set up from a laptop feeding a Stello DA220 DAc, then onto an Audio Technica HA2002 amp via single ended out, and a HeadRoom BlockHead via balanced out - should be interesting.
