studeb
- Nov 5, 2003
I am referring to the 100nF and the 220uF caps. C1, 2, 5, 6, 7 and 8 in 272A.
If they are there to block DC, do we need all of them?
My kit arrived last weekend, with some other items from family in Oz. It has the black poly caps.
i am trying to figure out what else could be done. How about a lower value for the pots? You could double the plate voltage with two 9V batteries, the L4949 is rated for 28V, so it would be fine. Is there a family member with a higher regulated Vout? Also the datasheet recommends C12 < 1uF. i know others have put OPA2134 for the opamp. Not much else to do, it looks pretty nice.
Originally Posted by sennsay /img/forum/go_quote.gif Hi studeb, which ones are you talking about? All of the 10uF caps are decoupling caps and that makes six all told and sure, they could be bypassed. If you've seen the pics I've posted, all of the blue caps are Phillips/Vishay 10uF electrolytic caps. If you meant the polyester box coupling caps, there are four of them and bypassing isn't really worth the effort, as you can just not use them and pop in there some 0.1uF or 0.47uF polypropylene caps (as Mark Houston has done) quite cheaply instead. However, in my case, since we are using a DC source here, I will probably just leave the 10uF caps alone - they're already very good caps - and use some of the wonderful little NX series 0.1uF Black Gate bipolar caps to replace the 0.1uF polyester box caps for the coupling duties. These things are stunningly good in that position and I've used them to great effect in my best upgraded version of the KHA II h/phone amp and other projects. Are you thinking of building one of these little tackers? |
