scootsit
- Oct 23, 2011
Sorry, I haven't been keeping up. I replaced the regulator with just a jumper. I really should have used a resistor and then decoupled the opamp with a large-ish cap. Anyway, it worked with a TS922 which is a CMOS based chip and doesn't really sound all that great (sibilant). But, it works and with a bit more tinkering, I should be able to do even better. The Millet Hybrid originally had a chip supplied by the same V+ as the tube, they were just separated by a 1k resistor with big decoupling caps to ground before and after said resistor, I'm thinking something like that should offer plenty of power to both the chip and the tubes. The 5V regulator likely does minimize drain on the batteries, so battery life is anyone's guess.
There are other super low power chips that work well as buffers. The OPA2835/2836 used in the pupDAC come to mind.
Gidday lordearl, have you managed to pop a pair of the AD825s in the amp yet? The OPA627's also sound fine, though need more grunt from the power supply to work as well as the AD825s do even with the stock supply. Very open and sweet, they do seem to overload in the bass quite easily, not sure if that's anyone else's experience, would love to hear more feedback on that one. Cheers all
