Hello. I happen to own both the CAL, TF10's and M-50s. SQ wise it would be TF10>M-50>CAL. I must say the difference between the CALs and M-50's aren't that big. The M-50s have a lot more bass and isolation, but otherwise the difference isn't that great. The CAL's are a bit brighter than the M-50's, with a slightly tighter bass, but a lot less quantity. The M-50's also seem to have a bigger soundstage, although I think that's because the mids are a *tiny* bit recessed. Both of them are pretty equal in sound quality. CAL's are $70 though.. their value monsters and dollar for dollar beat the m-50's in value. On the other hand the M-50's have a much better isolation, whilst the CAL's don't isolate or fold... personally I use the CAL's at home and the m-50's when I go out if I feel like using cans.
TF10's on the other hand smash both the CAL's and m-50s at detail, bass control and treble. Bass is pretty nice, but the treble is insane, detailed, fast and in large quantities. If you don't like treble, you might want to reconsider TF10's.. The soundstage is a lot smaller, but it isn't bad. Being IEM's, they also isolate much better than both cans and are far more compact (obviously). Build quality is decent, although TF10's rarely break due to the earpieces breaking, rather it's almost always the cable. Although I did say TF10's have the best sound quality, it's not night and day, and all three choices do sound great. Comfort wise all three are pretty comfy, although I can only wear TF10's for a few hours at a time since their so big (and ugly).
As for re-zeros, I don't own them, but I have heard them before. I remembered that they sounded great (from memory they were natural sounding and well balanced), although TF10's are in a different tier all together... The re-zeros do sound great, but your comparing a great pair of IEMs to a top tier iem. I'd like to add, though, that although the TF10's are faster, more detailed, have better bass control.. etc than the re-zeros, the re-zeros do have a more balanced sound signature.
Please note this is my opinion, I've expressed what I think these headphones sound like. The only foolproof way to check out a pair of headphones is to get a first hand experience.
