Be careful, most of those are vague in their description. Many are Balanced 2.5mm TRRS male to STEREO 3.5mm TRS female so you can use a regular stereo headphone from a balanced jack on your DAP. What Trinity's balanced cable needs is a TRRS balanced connector on both sides.You right. Sorry. There are many on Amazon:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=3.5mm+Female+to+2.5mm+Male+adapter&rh=i:aps,k:3.5mm+Female+to+2.5mm+Male+adapter
Is a nice one: https://www.amazon.com/Extreme-Audi...r=8-12&keywords=3.5mm+Female+to+2.5mm+adapter
Disclaimer: I am not hawking the adapters below. Just make absolutely sure you know what you are getting to be able to use the Trinity 3.5mm balanced cable with a 2.5mm balanced output from a DAP. Two examples I found that appeared to meet that need are below (there may be other cheaper options available but read the fine print):
https://www.amazon.com/Adapter-Bala...=2.5mm+balanced+Male+to+3.5mm+balanced+Female
https://www.amazon.com/Balanced-Fem...=2.5mm+balanced+Male+to+3.5mm+balanced+Female
Hope this helps...
Cheers!
-HK sends
