Jeff Graw
- Jul 10, 2007
Sorry if this has been asked before, but do PM6/Hunter preorders get the deal?
I see Master comes with one balanced cable of 3.5mm. The usual connector in DAP market (Cayin N5, Ibasso DX200, Fiio X5 III, Aune M1S, Fiio X7) is 2.5mm TRRS. Is 3.5mm then the correct data?
You can as long as you have a current order.
@Bobtrinity What is the point of having two codes that have the same discount? And how is it a trade up deal when anyone can use the code, even if they haven't bought a Trinity IEM?
I'm thinking of getting the AAW Capri (lightning cable to DAC to standard 2pin /or/ [COLOR=2A2A2A]MMCX (intended to plug in at the IEM) to use with the Master unless Trinity's DAC is coming soon and will have a lightning cable. Would the Capri likely work with the Master? Is the Master a standard 2pin?[/COLOR]
If you're eligible for it and can't wait for an email, you can always use the code TRADEUPPROGRAM mentioned in the blog post on Trinity's site. That's what I did after Bob confirmed current PM6/Hunter preorders are included in the offer.
I had no goal of inciting. just sharing and comprehensively touching on points made by other posts along the way.
I am very well aware: you bought it, there's no returning it, and that's that... and you try it out and you'll probably keep it... But others were considering different IEM's, making plans with other things, not with trinity, so it was helpful have it addressed and if they had doubts, then fine.
