1nilla
Anyone know how to connect tk-2 to Ipad pro?
Those iems will get lesser power, at least that what I heard. It is still nice for doing A/B testing though.Every output works at the same time.
Of course, we will. I will send you the email address of the after-sale service.@WendyLi it is confirmed that the problem is the stock usb c to usb c cable.
Will replacement be provided?
TK-2 will say: I am a little tired today
So yeah this is a thing you can do with the TRI TK-2. Every output works at the same time.
Now I've only tried it on low power as I don't want to potentially damage my TK-2 but at normal listening volume (for these low power IEMs) it was fine.
Balanced obviously is louder than SE, so using the lower impedance IEM on SE is recommended if using multiple outputs from the TK-2. I would also recommend having the IEMs on the balanced outputs to have about the same impedance if you decide to use both at the same time for some reason.
Now I don't recommend doing this all the time but for a-b testing this might help a lot.
Hi Nick, not yet, I have not had the opportunity, yet to listen to the Meteors, but give me a week or so and should be able to give my impressions. Do bear with me.@ChrisOc , have you had a chance to listen more, test, your Meteor? Your impressions, so far?
Definitely man, thanks a lot! In a week or so, I will also receive my FiiO UTWS5 -it has been shipped yesterday- and I will be able to decide if it will be a good match with my new FH5s, or not. Thanks again. all the best!Hi Nick, not yet, I have not had the opportunity, yet to listen to the Meteors, but give me a week or so and should be able to give my impressions. Do bear with me.
Thanks for the detailed response. Based off what you said I save up for the starlight and buy them duing the eventual CNY sale. While I like a harmonically coherent iem analogue is quite a big nono if used in the traditional BBC sense as I find old school audio technica too lush and rich and would much have a leaner denser sound with proper negative space to saperate the instruments.I will start with the Starlights, they are detailed and have exceptionally good resolution, as you would expect at this price range and with the driver combination. However, as you rightly pointed out some have reported that they find the treble overwhelming, I do not hear the excessive treble of which others complain. I would like to think it is not age or that I have any hearing deficiency. I just believe that I am more treble tolerant. In short I would say the Starlights are analytical in their presentation.
The Starshines on the other hand are quite analogue in their presentation, which, to my ears, is a much more harmonic as opposed to analytical presentation so that it is not about how distinct each instrument sounds and well demarcated the separation of instruments is but rather how coherent those the entire ensemble sounds.
Although I really enjoy listening to my Starlights, I prefer the presentation of the Starshines, which suits my taste in music. Some prefer the Starlights, so really, if you have not already done so, read a few reviews on both, as these are big purchases for most.
As stated above by @yaps66 he is enjoying the Starlights with the "right" pairing. Getting the synergy chain right can make either a great set to have.
Sorry not to give you a definitive answer but the truth is tastes differ and at these sort of prices the differences are in the margins.
I am not promoting anything, but I have just had notification on AliExpress that KBear/TRI has a sale on from 6th December until the 10th of December 2021, once you have made your decision.
Good luck with your decision and come back and tell us which you chose.
If what you mean by sustained and smooth upper treble is that it is well extended, I would say for my taste it is. If what you mean by smooth is that it is artificially smeared over and buttery, I would say, it is not, it is quite precise treble but substantial treble.Just as a final question does the starlight have both sustained and smooth upper treble response?
Oh nice, yeah I was thinking of booth DD and BA being able to adjust the air body as needed. If the starlight is able to do the full gammut from the nanosecond spike to fully sustained vocal reverb extension that would be great.If what you mean by sustained and smooth upper treble is that it is well extended, I would say for my taste it is. If what you mean by smooth is that it is artificially smeared over and buttery, I would say, it is not, it is quite precise treble but substantial treble.
It terms of comparison, I hear the piezo treble as thin, almost fragile.
BA to my ears, has a bit more substance to the treble note and the electrostatics being the most substantial without being a thick note, so electrostatic tweeters will give the violin notes a fuller body than a piezo would and yet capable of delivering very fragile notes as well.
I hope I understood your terms correctly.
