donkashyap
Man you just saved me I was going to order it came here to checkI just tried on iPad and it says accessories not supported
@WendyLi could you please check
I cannot get the iPhone adapter to work on an iPhone 7, unfortunately.Enjoy man I’m waiting on mine from 17 days
From people who already have the Tk-2 can anyone see if the included iPhone adapter works
Your iPadOS version?I just tried on iPad and it says accessories not supported
I need to know your system Version, please.
iPhone XS Max on ios 15.1I need to know your system Version, please.
Available for iOS14 and aboveiPhone XS Max on ios 15.1
My order was placed yesterday hasn’t shipped yet if the adapter won’t work it’ll kinda be pointless
Thanks That’s goodAvailable for iOS14 and above
No, maybe you are the first one, What is your mobile phone? I will ask my colleague. Very sorry for the problem.@WendyLi , to my dismay, the sound cut off then totally loss the sound from any ports of Tri TK-2 with both my mobile phone and hiby r5.
I suspect it is the OTG cable.
For your information, I do not use this TK-2 everyday and usually use it at home only.
Any other owners have the similar problem?
It happena to both my Vivo Y72 and Hiby R5.No, maybe you are the first one, What is your mobile phone? I will ask my colleague. Very sorry for the problem.
I do not have that issue.@WendyLi , to my dismay, the sound cut off then totally loss the sound from any ports of Tri TK-2 with both my mobile phone and hiby r5.
I have tried other USB C to USB C cables and they work without any issues.@WendyLi will any usb c to usb c cable work?
If yes, I will buy from the local electronic store to check if this is cable problem as I suspect or other problem.
Thank you Chris.I have tried other USB C to USB C cables and they work without any issues.
If possible, take the unit with you to the local shop and test the cable works before you leave (if you can) to avoid disappointment.
