InSides
- Jan 29, 2005
So, the addition of two monoblock amplifiers has me left with a lack of space to fit my two racks side by side.
Sadly, the only possible alternate location for the "digital" rack requires approximately 25 feet of cabling between the DAC output stage and the preamplifier. Now, the DAC output stage has balanced outputs, whilst the preamplifier only has unbalanced inputs.
With the notion that balanced cable runs can be longer than SE without picking up hum/noise along the way, I was thinking that I can move the rack, implement 25 feet of length of balanced cabling, and then perform the Balanced/SE conversion near the preamplifier.
To do so, I could either go with an active solution [opamp?] or passive [transformers]. I would prefer the latter, and was looking for suggestions for a suitable pair of transformers I could mount into a small box with a pair of XLR and a pair of RCA connectors. Put this close to the preamp and problem solved.
So, any suggestions for a nice pair of transformers? Cinemag is an option, but am not sure which ones to pick. Lundahl is another, but I am a bit hesitant to leave the "affordable" category.
However, I understand performance is paramount at this link in the chain, so I would be up for anything reasonable.
Much appreciated.
Much appreciated.
