Transformers for Balanced to SE conversion.
Nov 1, 2009 at 11:43 PM Post #16 of 35
Originally Posted by dsavitsk /img/forum/go_quote.gif
Also look at the Sowter 3575
These are cheaper than the Jensen, and more importantly, much easier to source given the fact I am visiting London next month.
Would you be able [much appreciated] to provide a connection diagram for my application? Meaning, balanced to single ended conversion?
The datasheet states that the transformer could be used for either unbalanced to balanced, or balanced to unbalanced conversion. I would be interested in the latter, of course, but it presents an interesting option should I need to reuse the transformers for a different application.
Thanks!
Nov 2, 2009 at 4:23 AM Post #17 of 35
what's the input impedance of your preamp?
Nov 2, 2009 at 4:29 AM Post #18 of 35
Originally Posted by luvdunhill /img/forum/go_quote.gif
what's the input impedance of your source?
You want the input impedance of the load, not the source, which would be his preamp. His preamp's input impedance is 24k ohms.
se
Nov 2, 2009 at 4:35 AM Post #19 of 35
se
heh, yup exactly what I meant to say
looks like all the right questions have been asked.
Nov 2, 2009 at 4:45 AM Post #20 of 35
Yup.
Though knowing the output impedance of his source might be useful. As long as it's solid state it's likely to be just fine. But can't hurt to ask just in case.
se
Nov 2, 2009 at 3:15 PM Post #22 of 35
Originally Posted by diditmyself /img/forum/go_quote.gif
Do you know how much Cinemags cost? Are they suitable for converting balanced to unbalanced instead of an opamp in a DAC?
The 15/15B is around $45 each if memory serves.
And whether they would be suitable for your application would depend on how they're implemented.
They're an input transformer, so if they're going to be the last thing in the chain in your DAC, they wouldn't be suitable. For that you'd want to use an output transformer like the CMOQ or CMOB series.
se
Nov 2, 2009 at 5:28 PM Post #23 of 35
See attachment. For more details, see Sound System Interconnection
For use right after a DAC chip, you probably want something more like a mic input transformer. Cinemag has these, as do Lundahl, Edcor, Electra-Print, Jensen, etc. MC stepups might work OK, too.
How to use transformers? Read this http://www.jensen-transformers.com/a...%20Chapter.pdf
Nov 3, 2009 at 9:55 AM Post #24 of 35
Thank you all.
I have contacted both Cinemag and Sowther. Since with shipping both options come out to be the same, I am a bit hesitant as to which one to pick.
I know this might boil down to personal preference, but I can't really afford to try both and then decide.
Jan 12, 2010 at 4:39 PM Post #25 of 35
Steve:
Somewhere (I cannot find it) you mentioned turning the Cinemag transformers around for a certain use and I believe there was a rationale behind this. I'm not sure how the shields are configured, and perhaps you've accounted for this?
Also, have you played around with a proper RC loading for the CMLI-15/15B? I've been playing with it of late.
Jan 12, 2010 at 5:03 PM Post #26 of 35
Steve:
That was for unbalanced/balanced conversion. Basically, just flip it around and the drive the secondary from the unbalanced source with the bottom of the secondary connected to source ground. Then place a pair of 7.5k resistors across the primary cum secondary and the node between the resistors becomes your ground, which is where you'll connect the can and shield leads.
Yeah. And I pretty much concluded that it's really only useful if you want to get a nice looking square wave. For all practical purposes though, I haven't really found any particular benefit to it.
I mean, a transformer doesn't resonate on its own. The resonance first has to be stimulated with a signal.
Calculate what the resonant frequency is for the 15/15B and you'll see what I'm getting at.
Though I must say you've done a pretty good job of it. What values were you using in that third shot?
se
Jan 12, 2010 at 5:18 PM Post #27 of 35
Ok! So, assuming you also want to do balanced->balanced through the input transformer, what happens to pin 1 on the XLR?
From top to bottom, those values are 18K, 15K, 10K with no capacitance and 50R input impedance. The trick is, the damping varies with the input impedance, which I was surprised to see. So, I'm not sure what a good "worse case" input impedance is. With 600R input impedance, I find I need 300pF + 10K. So, I think I'll stick with this value.
Jan 12, 2010 at 5:30 PM Post #28 of 35
When I do balanced/balanced, I use a pair of transformers per channel, wired mirror imaged in series (this will also handle unbalanced inputs).
I suppose you can drive the single flipped trannie from a balanced source, but since the secondary isn't balanced, you won't get the CMRR that you would if it were.
In either case, pin 1 gets tied to the chassis.
You mean 300pF in series with 10k? And this is also serving as the main load for the secondary?
se
Jan 12, 2010 at 6:41 PM Post #29 of 35
I'm not sure I follow, do you have a diagram?
yes indeed. After this RC, I am using a 100K pot
Jan 12, 2010 at 6:53 PM Post #30 of 35
Sure.
Ah, ok.
se
