I'm not sure where the 'best' place to get a Mutec from would be, but I'd imagine that any place that even has one in stock might be the 'best'.
And Markertek is probably as good as B&H or Sweetwater etc. or any of the other pro audio sources.
And the USB demarcation for the Mutec is really about an updated clock that it has, that its 'younger' brother (the non usb equipped version) doesn't have.
And there are other DDC's appearing on the horizon that are vying for a top position on this ladder, but they all seem to be even more expensive, imagine that…
Which brings up the question of where truly is the most bang for the buck in terms of these standalone clocks and reclockers and DDC's and the like.
They all seem to be taking the SQ up a step or 2+, especially in combinations…
Which just makes my head scratch as I wonder What is really, as in the big picture, going on with all of this.
It is a puzzle for sure.
Yeah I was sorta hoping that the ADAT ports were SPDIF as well, but I kinda figur'd AES would trounce it anyway.
And starting with a 'simple' AES breakout cable is a good place to start.
One of the tricks to making that cable is getting as close to an 'audio grade' DB-25 as possible.
And even using pro audio grade 110Ω cable has great results.
I just finished modding my RN3 and buttoned it back up.
And of course this re-starts the break-in clock all over again.
And Yeah I look forward to our next mini meet or what ever it turns into.
Techno-Talk always has that spark of creativity interspersed between what if, and oh wow…
JJ
"Any place that even has one in stock might be the 'best'" ... yep, totally getting that! MarkerTek it is then ...
It'll be interesting to see where the DDC market goes. Stuff like the Intona Isolator has proven problematic for me with various Network Audio Interfaces. Definite benefits when it works (though still yet to exceed simple, good-quality, TOSLINK). But then you know how I am about USB stuff in general!
I'm with you on the head-scratching. I can see, from an engineering perspective, why putting multiple "noise filters" in series would make a cumulative difference. It's harder to compute when we're talking about re-clocking. That should be an absolute ... if unit "A" can re-clock to n/ppM, then having two of them in series shouldn't improve that ... but it wouldn't be the first effect I could hear but couldn't explain.
When I ordered my RedNet 3 I snagged a basic DB25/XLR snake. I'll make up a more "serious" cable once I have everything installed and working (fingers crossed, that'll be later today). Then I'm going to run my comparisons with the Aries, SonicorbiterSE, my Linn units (which are much more than just AoIP interfaces) and whatever else comes up. And from there I'll start fiddling with more interesting cabling.
Any recommendations for "audio" grade DB25 connectors? The XLR side I can cover, but the DB25 stuff I'm more used to dealing with for legacy parallel interfaces and multi-channel serial connections rather than anything approaching audio applications.
We need to set something up sooner than later ... and you need to see the new music room ...
