CAT vs TotalDAC d1-Server
I do not take the statement of the CAT being superior to the TotalDac server lightly because the TotalDac server is excellent. If I was forced to live with the TotalDac server, none of you should feel sorry for me because this server thus far is the second or third best music server I have heard (the Aurender N10/W20 is somewhere in this mix). The CAT does not include a separate reclocker in the same way that the TotalDac server does but unlike the TotalDac server, it does have incorporated in the chassis 2 high precision clocks (explained in further detail below) that then feed the USB port a very clean and well timed signal. As you know, using the CAT as the source, the TotalDac reclocker seemed to result in only a subtle improvement. Since the USB Regen seemed to have no noticeable effect on the CAT at all, my suspicion is the improvement heard with the TotalDac reclocker has less to do with jitter control and more to do with converting the USB signal to AES/EBU making this a TotalDac issue and not a CAT issue. As has been mentioned by Vincent, this is the port the TotalDac prefers.
As for statements about performance vs value, my statements of preference were regards to performance only. When talking about value, I have to answer this question carefully because there are many variables that have to be considered when you talk about the value of a server for most people. There are some who prefer not to use a NAS and believe that internal storage is superior when it comes to SQ and convenience. There are some who prefer the familiarity and compatibility of a well known OS like Windows or IOS and others who prefer the open source flavors that Linux provides. There are many who would prefer not to deal with OS issues at all and would be happiest to have an easy to use and reliable user interface, preferably on a tablet. Further to that, there are those of us like
@bmichels
that insist on having ROON capability. Once you know what you must have, it becomes easier to make a decision.
With regards to price, if you owned only a d1-dual, you would have to pay nearly 5,000 Euros for a d1-server which as you know, has a reclocker built in. If you are interested in a d1-monobloc, the reclocker is an included part of this package and to add the server adds only about 1,000 Euros and so for the monobloc, getting the server is a no brainer. There are some creative souls out there who own a TotalDac DAC and have purchased a Cubox computer for about $100 USD and are connecting these little devices to the TotalDac via USB and are claiming excellent SQ. This may present the ultimate value if you already own a TotalDac DAC and are considering the Server.
While I hope most people recognize that I regard the TotalDac server extremely highly with regards to SQ, there are issues with it that are less than ideal. Most importantly is the software. While it works well, MPAD is 2nd rate. It's last update took place in early 2014 and it has bugs. Also, to listen to Tidal or Qobuz, you have to switch to iPeng which is 3rd rate and clearly sounds inferior to MPAD and so if much of your listening is through these streaming services, you take a SQ hit. When using Tidal or Qobuz on iPeng, the feature set is very primitive. It's really hard to discover new music this way. Basically, with any Linux-based system, you seem to get the latest stuff last and what you do get isn't very polished. The way I see it, the TotalDac Server is a 1st rate server with 3rd rate software. While it excels in sound quality, it does not excel in overall user experience and so you will have to decide for yourselves what value this holds.
With the CAT, you pay more but you get more. In most cases, the price for the CAT will be nearly double but what you get is an attractive looking chassis that can be left on 24/7 and consumes less than 20 watts. It also runs extremely cool to the touch and so for a full PC that runs Windows 8.1, you know the hardware is very light. The OS has been optimized through 3 years of tweaking and only runs 30+ active processes. To keep it running efficiently, the default configuration is locked although there are ways to unlock it if that is what you wish. There is no firewall, no antivirus, no Windows updates as this is discouraged and considered unnecessary for a music server. While you can use it like a standard PC, you really wouldn't want to because that defeats its singular purpose and that is to present music with the highest quality possible. Before you laugh at the choice of Windows 8.1, in many ways this was a very smart choice because of Windows' robust networking capabilities and very broad compatibility. Software also tends to get released first for Windows and while we are still waiting for ROON for Linux, the CAT can be configured to boot directly to ROON now which you can then operate remotely using either an iPad, Android tablet, smartphone, PC or MAC. Because it is a standard PC, it will run all software that Windows can run including Spotify, YouTube, Rhapsody, Sonos, etc, and hopefully MQA when it is released. This is probably as future proof as you will get. The best thing is that all of this can be controlled via remote desktop software so you can keep the CAT on your rack without having to connect it to a monitor or keyboard and you can control it from any other PC or Mac or even a tablet. Because the OS has been optimized for stability, it is designed not to crash like most PCs. Thus far, it has been 100 percent stable.
Unlike the TotalDac Server, the price comes with internal storage which presently maxes out at 4TB of internal SSDs although the CAT can utilize a NAS if necessary. Before you start thinking you can build this machine on your own, you can't. The SSDs are not off the shelf SSDs you can buy, they are custom built for the CAT with proprietary specs geared for music listening. The SSDs are individually encased/shielded and carefully mounted to guard against resonances. The wiring (both data and power) is hand made with careful attention to keeping lengths to a minimum. Much testing was done with different metals before deciding on what type of wiring sounded best. The motherboard is heavily modified with a customized bios that took years to tweak. The motherboard uses 2 oscillators/clocks that receive a highly filtered DC voltage from an outboard linear power supply. There are no motherboard switch mode regulators between the oscillators and external power supply. There is also additional filtering applied as close as physically possible to both oscillators. His USB ports are of his own design and are fed by a dedicated rail from his external linear PSU. The unused ports on the CAT have been deactivated. What Scott has found to be one of the biggest issues in digital audio is high frequency noise that results in digital harshness and so he has spent 4 years trying to eliminate or minimize it using a variety of methods and technologies that he did not feel he could share with me. Unlike many components that are over-engineered for no real reason, the CAT is precisely engineered because the difference is there.
The CAT took 4 years to develop and when you focus 4 years of attention to a single product and you have the attention to detail that Scott has, then what you end up with is something pretty special. To give you an example, Scott reportedly tested more than 30 fuses before deciding on which fuse sounded best on the CAT. Who does that? Even recently, he has been experimenting with different materials for cabling and recently upgraded the DC cables to his external PSU when he realized the SQ difference was there. He sells a USB cable that recently was granted a patent for its differential filtering capabilities. What these efforts amount to is what I have now experienced first hand -- the best digital source I have heard. Sometimes, you do get what you pay for.
