Toslink is not so bad after all
May 20, 2019 at 12:43 PM Post #16 of 50
Most digital connections are indeed bit perfect because they employ error correction. When it comes to audio there is no error correction since audio is a time sensitive application. In my earlier statement on bit perfect I was only referring to audio, not e.g. file transfer.
Hans Beekhuyzen has a great video on the topic:
I can only advise you to avoid the technical videos from that man. he's very good at providing complete audiophile nonsense between two slices of basic facts. I'll just quote this golden nugget "our ears are still far more discerning than the best audio measurement equipment available".
consider his examples compared to a more realistic audio application, the example about the change in amplitude creating an error would require your noise to be at amplitudes close to the actual digital signal, such a situation would probably fail to even play music. as for getting one error out of 4 bits, that's just another massive exaggeration compared to any viable audio setup. yes those stuff 'could' happen with garbage gears and conditions, but the magnitudes presented are completely unrealistic when it comes to even cheap modern products. read about jitter from research papers instead of audiophile gurus, scientists do bother looking up the magnitude of something before crying wolf.
also I must point out that if you're so worried about errors and jitter, then async USB seems like a much better solution than worrying about how to get the best optical stuff from fear of unconfirmed issues. not that I believe either options to be problematic with most gears. I'm only talking from the point of view of someone paranoid about jitter. personally I can only give a simple anecdote, I can measure a few things, often with a resolution good enough to be able to notice when a device or combo of devices result in a serious problem. but I cannot measure jitter because the values are typically so small my cheap ADC can't accurately quantify it.
May 20, 2019 at 1:01 PM Post #17 of 50
A university (in Japan iirc) conducted a test were subjects listened to music, once with frequencies up to 22kHz and then music with no frequency cap. Whilst listening, an MRI of the peoples brains was made, and in every case when a sample with ultrasonic frequencies was played, the brains showed significantly more activity compared to redbook sample.
The moral of the story? Just because our conscious mind is not able to make out certain sonic elements doesn't mean, that said elements don't affect us and add to the listening experience.
No he is not. Watch the video before making assumptions.
this argument reminds me of this one:
If I have internet, then I have seen a naked girl.
I don’t have internet, therefore, I have never seen a naked girl.
May 20, 2019 at 2:29 PM Post #18 of 50
It actually wasn't considerably more. They just could see a difference on the screen. But they would also be able to see a difference on the screen if you were cold, if you had to go pee or you were sitting on a tack. Perceiving in the most general sense is not the same thing as hearing, and hearing is not the same as listening to music. There have been studies where people were given two samples of recorded music, one with superaudible frequencies and one without, and the listeners were asked to choose which one sounded best. Most people said they couldn't tell a difference, and the ones that did express a preference fell into a random pattern. Then they filtered off everything above 10kHz and did it again. This time, some people could hear a difference, but most people still said that they had no preference and the ones that did fell very close to random.
Super audible frequencies do nothing to improve the sound quality of recorded music. They can't help, they can only hurt. (see CD is all you need in my sig file)
I'm not sure what superaudible frequencies have to do with jitter, but I guess it is more likely for jitter to happen in super audible frequencies. The solution for that would be to filter out all the noise above 20kHz.
May 20, 2019 at 3:02 PM Post #19 of 50
@bigshot
Yes it was. Without high frequencies there was no activity over baseline in the parieto-occipital region, the thalamus and the brain stem whereas with high frequencies there was activity over baseline in all subjects in said regions. Also the general alpha eeg activity over baseline with high frequencies was about 6x higher compared to the elevation without high frequencies.
May 20, 2019 at 3:15 PM Post #20 of 50
Why is that? Have you done a listening test to make sure you can actually hear jitter, or are you just operating on theory? Because I would really like to find someone with first hand experience who can describe exactly what jitter sounds like. The only descriptions I've heard are the typical subjective error descriptions, like veils or muddled imaging, or sympathetic magic like vibrations or stuttering.
USB is 'universal' therefore not especially good for anything, least of all audio. I've had to work with it professionally many times over many years, and it has always posed more problems than solutions. I avoid it whenever I can.
Nobody I know can hear jitter, but we all hear its side effects, which vary all over the map depending on everything from source material, to several sorts of analog signal chain distortion, all the way out to transducer type and resolution.
How it presents depends on how it's exposed.
It's hard to quantify outside a lab, with (usually expensive) test equipment, so everybody mumbles and waves their hands.
Since isochronus transfer is source clocked, the troubles usually start there, with something as simple as a noisy power rail.
Enter reclockers, jitter buffers, et al, and Maybe it sounds good enough in the end. Maybe not. In any case, the result is usually a sort of degradation we find unmusical.
SP/DIF seems less fragile, if only because it's simpler. AES/EBU is better still, if available.
May 20, 2019 at 4:01 PM Post #21 of 50
What consumer equipment has audible levels of jitter? I can see worrying about things like this upstream in recording studios when you're mixing, but with playback systems in living rooms, I can't see it being a real world problem at all.
I'm not arguing that there isn't some sort of perception. I'm just asking how does this relate to listening to music on a stereo system? If you can't hear it, why does being able to sense it in some unconscious way matter?
May 20, 2019 at 11:30 PM Post #22 of 50
At least the puppy can hear higher frequencies :)
@bigshot
I think you've only seen consumer news articles on this study. Medical research does not operate this way, and is not what the actual results reflected. The study did show that there was elevated thalamus activity (but different statistical rates within different frequencies). This is also far from a conscious perception.
How do you transfer computer data then?? It's "universal" because it's an accepted standard that's on every computer. Look at any modern laptop, and all you'll see are a couple USB 3 and USB C connector. Please explain to me how a "clean" signal makes 1s and 0s "better" (even audibly so) and how my "dirty" USB connection might somehow be corrupted (that I use all the time for work for databases and medical animations, transfer higher bandwidth 4K videos, as well as keeping a music library on my work rig)?
May 21, 2019 at 1:20 AM Post #23 of 50
Because from what I have gathered over the years it does matter. Take tubes or a NOS dac for example. I'd argue that there is enough empirical evidence that people attest a certain pleasentness to their sound. And since the most significant difference compared to OS dacs or solid state is, that tubes and NOS add even order harmonics. Also way below hearing threshold. Yet people seem to perceive it.
I do own a copy of the study and see my response to bigshot regarding perception.
Please watch the video I posted earlier in this thread which explains why clean matters.
May 21, 2019 at 2:42 AM Post #24 of 50
How does something you can't consciously hear matter? I can't see gamma rays, and I don't require my camera to accurately reproduce them. The silliest thing about this is that the inaudible frequencies we're talking about are only an octave or two... just a do re me further than we can hear. And music doesn't generally contain these frequencies anyway. Super audible frequencies are as useful as teats on a bull hog.
NOS DACs sound different because they have brick wall filters that aren't perfect brick walls, rolling off at the high end. Oversampling was created for the filter, not to add super audible frequencies. Tube amps can sound clearly different. The harmonics are not below the range of audibility. None of that is unconscious.
I'll make you a deal... I'll watch your video and answer it point by point if you go through the links in my sig file and do the same.
May 21, 2019 at 3:31 AM Post #25 of 50
@schnesim
one of the clear benefits of digital streaming is how it allows to retrieve the original data despite some moderate amount of attenuation, noises, delays... the very thing you start by dismissing in your argumentation is a core reason why digital transmission is interesting. yes there will be a threshold beyond which errors become frequent. put too much of anything anywhere and you'll have troubles, even water is a poison if you drink ludicrous quantities, does it mean we must try to avoid any amount of water now that we've established the lethal effect of water? this is not a viable way of thinking(literally). if you never try to consider what the relevant threshold is for a given variable on a given system, then you effectively have no idea about the amount of errors and their possible impact on the DAC's output. all you're really doing is projecting your own phobia of digital errors.
and of course it's the exact same issue with hearing thresholds. they do exist and we have a very finite ability to sense things. feel free to think that the stuff going on probably below -100dB due to your digital setup is what makes you enjoy or dislike music if that's your ideology, but good luck making this into a falsifiable idea that will resist experimentation with music content.
May 21, 2019 at 4:46 AM Post #26 of 50
[1] Cleverly, both data and clock may be combined in such a way that both can be derived from the demodulated signal. But the process is never quite perfect, and one of those imperfections is called jitter, a simple indeterminancy about the incoming clock and its related data.
[2] AES uses higher signal levels than SP/DIF, so signal-to-noise is likely to be better. [2a] And better glass in a Toslink jumper is likely to be audibly better for the same reason. [2b] It's just case of having more signal to work with when you go to demodulate.
[2c] I'm a retired communications engineer, and I've worked with high datarate fiber runs of kilometers plus having miniscule bit-error-rates, and I can assure you that all these kinds of things are well understood in the industry, and there's no magic at all in getting any signal from point A to point B. If cost isn't the primary concern, which is almost never the case.
[3] But there are many, many things that can go wrong, and that's especially true in cost-costrained consumer goods.
[4] That said, I don't let USB anywhere near my music, and use coax and glass where appropriate. :beerchug::beerchug:
1. Correct, the process is never perfect, clocks are not perfect, clock recovery/processing circuitry is not perfect and there will always be some amount of jitter. The question is (or rather was, about 45 years ago!), how low does the jitter have to be in order for it to be inaudible.
2. Again, digital audio is binary and therefore has just two states, zero or one (on or off), there is no 3rd state for noise! The signal to noise ratio therefore has absolutely no effect whatsoever, providing there is not so little signal and/or so much noise that a one cannot be differentiated from a zero ...
2a. So, better glass in a Toslink jumper/cable will NOT be audibly better, for the above reason!
2b. No it is not! It's a case of having enough signal to be able to differentiate a zero from a one, more signal than that makes absolutely no difference whatsoever, you get EXACTLY the same zeroes and ones!
2c. In you home audio system are your digital interconnects "runs of kilometers"? With long cable runs we both loose signal and gain interference/noise, a double whammy which can/will cause issues and requires solutions. AES is specified with a higher SNR for this exact reason, for commercial use in say recording studios where we may have several/many tens of meters of digital cable runs. With a typical consumer digital cable run of just 2 or 3 meters or so, then SP/DIF or AES has absolutely no impact on data integrity. If you are/were a communications engineer how is it possible that you don't know this? Maybe you've only dealt with kilometers of cable runs and never considered or learned what happens over far shorter distances but I find that hard to believe of a qualified, experienced engineer.
3. There are indeed many, many things that can go wrong, however all of them have been addressed! In fact, they were addressed so long ago and technology has advanced so much since then, that it now costs peanuts to address them. Your statement is therefore false and in some cases the EXACT opposite of what we actually see: It can be "especially true" in some expensive audiophile products, which in an attempt to differentiate themselves in a crowded market sometimes employ bespoke, esoteric designs which fail to address the problems that cheap DACs have overcome. When you were a communications engineer, did you state that a system/project was completed based purely on your assumption that it would work or did you objectively test and measure it's performance first, in order to avoid making false statements and appearing ignorant or incompetent?
4. I've objectively measured and tested digital audio data transferred over USB, AES and SP/DIF and in one case, well over a decade ago, had a very modestly priced USB audio interface run continuously for several days with not a single bit error. What have your objective measurements of USB DACs demonstrated?
[1] Hans Beekhuyzen has a great video on the topic:
[2] A university (in Japan iirc) conducted a test were subjects listened to music, once with frequencies up to 22kHz and then music with no frequency cap. Whilst listening, an MRI of the peoples brains was made, and in every case when a sample with ultrasonic frequencies was played, the brains showed significantly more activity compared to redbook sample.
[2a] The moral of the story? Just because our conscious mind is not able to make out certain sonic elements doesn't mean, that said elements don't affect us and add to the listening experience.
[3] And since the most significant difference compared to OS dacs or solid state is, that tubes and NOS add even order harmonics. [3a] Also way below hearing threshold. [3b] Yet people seem to perceive it.
1. On what basis is it "great"? Is it great because you liked and/or believed it? Is it great because quite a few other audiophiles liked/believed and quote it? In terms of audiophile marketing, I could possibly agree that it's "great" but in terms of the actual facts/science it's pretty much the exact opposite! Unfortunately therefore, you posted that video in the wrong forum, this is NOT an audiophile marketing forum, this is the sound science forum.
2. Yes, I've read that paper. While the MRI demonstrated a difference in certain brain activity, the subjects themselves reported experiencing no difference.
2a. How can it "add to the listening experience" if there is no difference in the experience? How then is that the "moral of the story"?
3. If you're referring to NOS DACs, then they are typically also filterless and therefore do not add even harmonics but fail to comply with digital audio theory and remove alias images, which are harmonically unrelated.
3a. No they're not, they're typically significantly above the threshold of audibility and an order of magnitude or more above the jitter and other digital audio artefacts found in even quite cheap DACs.
3b. People can easily perceive differences even when there are none whatsoever (see the "McGurk Effect" for example), which as demonstrated is purely an effect of how we "perceive", actually hearing a difference is entirely a different kettle of fish though and when put to a reliable test many of those perceived differences typically vanish. This isn't applicable in this case though, the affects of tubes and NOS DACs is above the threshold of hearing and can be differentiated in reliable (double blind) testing.
[1] Nobody I know can hear jitter, but we all hear its side effects,
[1a] which vary all over the map depending on everything from source material, to several sorts of analog signal chain distortion, all the way out to transducer type and resolution.
[2] Since isochronus transfer is source clocked, the troubles usually start there, with something as simple as a noisy power rail.
[3] Enter reclockers, jitter buffers, et al, and Maybe it sounds good enough in the end. Maybe not. In any case, the result is usually a sort of degradation we find unmusical.
[4] SP/DIF seems less fragile, if only because it's simpler. AES/EBU is better still, if available.
1. No, we do not! This is the sound science forum (and you were an engineer were you not?) so where's your evidence?
1a. Yes, the effects of jitter do vary all over the map; random noise, sharp spikes and other artefacts for example. However, at what level? There are some cheap consumer DACs where the highest jitter artefacts are at -130dBFS, at least an order of magnitude below audibility and even below the theoretical Nyquist/Johnson noise level of a component/system. No one can hear that or any side effect of that, let alone "we all" being able to hear it!
2. Yes, again, the problems did start there, decades ago but were solved many years ago and today the effects are reduced to way below audibility with just a couple of bucks worth of components. And if a DAC designer cannot deal with "something as simple" and common as a noisy power rail, that is the very definition of incompetence! Again, even a cheap $60 consumer DAC can isolate itself from even a very noisy USB output from a computer/laptop to levels well below audibility, why then is it apparently such a "trouble" for more expensive audiophile DACs?
3. "In any case, the result is usually a sort of degradation" that should be well below audibility and therefore we CANNOT find it "unmusical", musical or anything else! Notwithstanding the possibility of an incompetently designed/faulty audiophile DAC.
4. AES/EBU is better if you have very long cable runs but if your digital interconnects are 3m or less (or even 5m in most cases) then it is not better, data recovery is the same!
The above is ALL a prime example of what I mentioned in my last post: It's all just regurgitations of audiophile marketing fallacies and falsehoods, regurgitations that we've seen posted here countless times, which have been demonstrated/proven false years ago. If they do start regulating "fake news" on the internet, most of the audiophile world would go up in a puff of smoke and about 95% of the posts on headfi will have to be removed! :)
G
May 21, 2019 at 5:04 AM Post #27 of 50
Then you didn't read the paper carefully enough as it clearly says on p.8. (FRS = full range sound, HCS = high cut sound)
In addition, subjective evalu-ation by questionnaire revealed that FRS intensified the sub-jects’ pleasure to a significantly greater extent than HCS did
May 21, 2019 at 8:04 AM Post #28 of 50
Then I'm not sure you know how to correctly interpret a medical study when you said:
... and in every case when a sample with ultrasonic frequencies was played, the brains showed significantly more activity compared to redbook sample.
No, the study didn't conclude all brain activity was higher (BTW, their sample size is just 12 people). It also didn't conclude there was a net positive experience subjects encountered with high frequencies. Your other reply that I quoted also didn't include the ranges that were conducted. For anyone interested in the study:
https://journals.plos.org/plosone/article?id=10.1371/journal.pone.0095464
And what they say:
"The hypersonic effect is a phenomenon in which sounds containing significant quantities of non-stationary high-frequency components (HFCs) above the human audible range (max. 20 kHz) activate the midbrain and diencephalon and evoke various physiological, psychological and behavioral responses. Yet important issues remain unverified, especially the relationship existing between the frequency of HFCs and the emergence of the hypersonic effect."
Please don't confuse topics. I asked about USB with a member who says they avoid USB. Your video specifically says it's about audio, and that it's a format that instead of just ones and zeros is also dependent on a clock (and also says other interfaces are excluded).
May 21, 2019 at 8:16 AM Post #29 of 50
Objectivist/subjectivist memes aside, choosing USB for audio transport isn't a religious choice, and isn't a choice at all if it's the only interface provided. I vote with my wallet and rarely buy audio things that don't offer better options.
Around here, USB is mostly for power distribution, and while I don't think it's especially good even for that, it mostly works, most of the time, and is too common to completely avoid. As a lowest common denominator solution, and so long as life and property are not at risk, I have no objections.
I also don't allow Windoz anywhere near my music. I know that many people work very hard to make both Windoz and USB work acceptably well for music production and playback. I don't, personally and for purely selfish reasons, consider that time and effort very well spent.
Choosing to believe my own ears, however imperfect, is also not a religious choice. At the end of the day, it's actually the only choice that matters.
May 21, 2019 at 8:23 AM Post #30 of 50
@bigshot
That means nothing. I have been trained in psychology at a university that focuses on research and is very active in neuroscience research. My ex also did graduate level studies on perception and memory and we have spent many hours studying and discussing these matters. We know almost nothing about how the brain creates reality. Simply finding activity does not offer any form of proof at all of what you are implying, it simply means there is a difference in activity, nothing more, nothing less. It might be important and it might be meaningless in the context of your discussion.
How big was the sample size for this experiment, what controls were in place to ensure that the participants may not have been responding to some other stimuli that triggered the activity? Well done experiments are both difficult to design and implement and sadly they are far less common than you might expect. So it is fine to suggest that the Japanese research suggests something, but please do not over-extend it beyond the barest of possible correlative evidence, it does not in anyway suggest causation.
