The more I listen to this amp, the more I love it. The bass has some serious attitude, and the highs are very resolving. Can't wait to try some tube rolling... first time for me.
For me personally, I have never had an amp that sounds this good. It's really something wonderful to think that I can build (and sell) an amp with this kind of quality. THANKS DOUG!!
I have been busy building several "built" versions of the Torpedo III. In between time, I have been listening to every different tube I can get my hands on. Unfortunately, my ears are over-whelmed at this point. There are a few tubes that are obvious to me as not-so-good-fits, but the rest are completely confused in my mind. The not-so-good-fits I've already mentioned - the 12AX7 is so-so but acceptable if you need wildly high gain; the 12AZ7 I did not like very much.
The rest have obvious differences, others not so much. I can say with certainty that the 12AT7's are a great alternative with an obvious difference, but am at a loss to really explain that difference at the moment. Here are some of the others I've tried, in no particular order:
- 6072
- 6201
- 12AV7
- 5965
- 12AT7 (both NOS and NEW EH)
- 6829
- 6414
I suspect the 6829 and 6414 may have super-potential, but the pairs that I have are not matched very well and it makes it difficult to tell. There is also the E180CC/7062, but it seems destined for audiophile-sticker-price-stratosphere. Similarly, the pair of 5965's I have are not well matched. There are flashes of greatness, but then my ears get tired and I start questioning whether I've really heard something different or not.
I am going to suspend all listening soon and do some RMAA's, which is a quite good tool (despited NWAVGUY's accusations) if you use it for direct comparisons. The plan is to come up with some graphs that show a number of these tubes together, assuming all else is held constant.
P.S. Most every 12AU7 tube - including the 5963 - sound great in the amp, but that's with Grados. As Dsavitsk mentioned, they probably don't have enough gain for typical high-impedance phones.
