jasonb
- Sep 14, 2010
This thing reminds me of my old LG V10 but with a bass boost switch and more power. The way the treble is presented is what reminds me of it most. I like this thing a lot.
I did some more portable listening earlier this week with the NX4DSD and HD650s with hi rez classical music. It continues to impress. Has anyone compared the NX4 DSD to the Nano iDSD BL?Honestly, it's similar enough to my Oppo HA-2 in terms of "how good is it"...you get some difference here and there, but they're honestly every bit as livable/usable and I wouldn't say one sounds better than the other. It's a winner for $150ish and definitely has a ton of power on tap.
Nope...but I have the XDSD. Go to the HA-2 thread for my thoughts, and they're basically about the same this case to be honest. The iFi stuff is "better", but it really comes down to presentation and taste.I did some more portable listening earlier this week with the NX4DSD and HD650s with hi rez classical music. It continues to impress. Has anyone compared the NX4 DSD to the Nano iDSD BL?
no problems with IEMs...again, this little guy is a strong bet for anybody looking to spend $150ish.How does the NX4 operate with low impedance iems? Will be using with the psb m4u 4. Any hissing or channel imbalance?
Anyone here use it with an iPhone, if so what cable are you using?
Seems have to answer my own question, Other website already give a clear answer but sad truth, there's a bug in fiio x5iii that streaming apps like tidal or Spotify, all digital output cant out from USB, must be from analog output... total bummer...Question, how to connect this NX4DSD to fiio X5 3rd Gen... ? I already quick google, but no good solutions....
