Surprised to see people raving about it here on Head-Fi. Just shows how sceptical you need to be when hearing other peoples opinions.
I've had mine for months and have stopped using it. It sounds pretty flat and dull with all my headphones and IEM's. First of all, it doesn't really have the power to drive full sized headphones, it barely amplifies the signal. The built-in DAC is just awful, can't stand listening to it. With IEM's the output is sufficient, but I don't have any devices that can't drive my IEM's properly anyway, so the only point of this amp would be to get better sound quality, but you don't.
Using it with a Sansa Clip Zip? Sounds better without this amp.
With a FIIO X1? Sounds cleaner without this amp.
With a FIIO X5? Again, sounds MUCH better without this amp plugged in.
With a Galaxy Note 3? Even this mediocre smartphone sounds a tiny bit better without this amp.
What's the point of an amp that:
A: Barely amplifies the signal and can't drive full sized headphones.
B: Doesn't provide better sound quality on any device. Either using it as an amp or as a DAC, it sounds worse when you use it.
Only good thing about it? The battery lasts for weeks. Which isn't surprising considering it doesn't really amplify the signal by a meaningful amount.
Save you money for something better guys. Mine is for sale btw, just ordered an E12.
