xtiva
Just got OPAMP from Burson Audio, V6 Vivid descrete Opamp, as a free trial today which came with the adapter cable to be used in the DX7 pro DAC/amp, as
Was very skeptical about OPAMP and how much of improvement it could make to the sound of the amp. Thought it could be some sort of audio myth like power cables…. Luckily Burson Audio gave me chance to test this myth out.
Was more interested in improving sound quality of headphone out of the DX7.
I have not listened to DX7 headphone out as it just didn't sound any good compared to my other amps, minds you they costed 3~4 times cost of the DX7. Dull with very cramped soundstage, compared other amps I had at home. The difference was night and day.
To test, I am using Sonnet Hermes as streamer running Volumio, streaming local content, FLAC files, connected to DX7 via Coaxial RCA cable. Headphone I have used was Sennheiser HD800S.
To compare this amp I have used SPL Phonitor X fed via Aqua La Voce S3 which was connected to Sonnect Hermes using I2S RJ45 connection.
I know it is not a fair game but it will be interesting to see how much of change OPAMP has made.
Burson Opamp V6 Vivid and extension cable that came today in beautiful box.
Opened the case and slid out the board for the DX7 and installed OPAMP into my headphone out circuit
Made sure to bend the pin nicely, listening to @CJG888’s warning message before putting things back into the system.
turned on the DX7 and let it warmed up for 30 minutes or so.
Time to listen to the music, I am a classical music listener and can’t tell the sound if playing non-classical music… hence music selected are all classical music.
Played my usual test music, first was my favorited Yo Yo Ma's Bach Trio album. Immediately I can notice the difference in sound quality. It now has amazing treble extension that you weren't able to get with the stock OPAMP. At same time instruments are now well defined and separated. Soundstage has widened enormously, improvement in depth of the soundstage was only marginal unfortunately. Now bass is so much more tighter and deep bass sound cell is very well defined.
Now moved on to Wind concerto, Vivaldi Oboe & Bassoon Concerto. Immediately you hear oboe's now sounds so much better with sparkles and bassoon's deep bass was very tight and well defined.
Now to test vocal, listened to Vivaldi Virtuoso Cantatas sung by Counter-Tenor. Vocal is bit forward than what I would have liked but vocal still had the sparkles in treble and sound separation is awesome with good soundstage width .
Now comparing this to SPL Phonitor X, which costed 4 times more than DX7 but this is only other amp I have. I know its not fair but DX7 kept really well to this amp. Only thing it just couldn't keep up with was detail retrieval and depth of soundstage.
Now I swapped out the Opamp from Headphone out circuit to DAC line out to test out the DAC portion of the device.
Sonnet Hermes was feeding the DX7 pro via Coaxial RCA and then it was connected to custom SET Tube amp via single ended RCA connection.
Opamp has somehow cutout that usual Sabre treble peak.. not sure might need to listen to this for longer as I have only listened to this for less than half a day. Soundstage has definitely been widened, like the headphone out, Bass has also been extended as well.
Never thought this little device could make this sort of dramatic changes to sound.
Will compare this to sparko once it arrives. It has been more than a month but still no sign of the Opamp.
Last photo of my audio shelf on tope of my desk.
