Just a word of caution to all you fellow DX7 Pro owners out there:
This morning, I was listening to my DX7 via the balanced output, and noticed that the left channel was intermittent. At first, I suspected a dodgy connection (as you do), but then I noticed that the signal came and went when you tap on the case. I opened it up, and found that one of the op-amps for the headphone output (Burson V6i Classic) had come out of its socket, and the pins were only just making contact… Those Audiophonics extenders are so darn springy! In the end, I bent the pins slightly to ensure a tighter fit: problem solved.
