Topping has taken their USB ground loop problem seriously and released 2 new products, one like the ifi iDefender+ and one like the various standalone USB interfaces that has the USB isolation built-in...
My D90/A90 had lots of noise related issues to resolve, and it looks like Topping took the solution to heart, IDK if they copied ifi's iDefender+
or if it has other functions, but the Topping HS01 form factor is similar and costs the same as the ifi iDefender+, but has a metal case instead of plastic:
TOPPING HS01 USB 2.0 High Speed Audio Isolator
https://apos.audio/products/topping-hs01
Topping came out with a more elaborate solution + other digital interface features
TOPPING U90 USB Bridge
https://apos.audio/products/topping-u90
The main Topping English website doesn't have these yet, and it looks like Apos got an exclusive, I received their newsletter announcing these new Topping products about 30 minutes ago
And, now I hope Topping does the right thing and builds these noise abatement functions into their future DAC products.
Originally posted on ASR:
I woke up yesterday morning to a pleasent surprise, a
Topping HS01 had already been "ordered" on my account at Hifigo.com, and the HS01 is already shipped and on it's way to me. I guess they hoped I'd say "yes" to the request for testing, and they were correct.
It looks like my long drawn out squawk about my Topping A90/D90 "noise" issues posted on ASR is coming around again for me to test new solutions.
A few months ago I put out an RFQ to
World's Best Cables on Amazon to custom build 4 cables of lengths 3' and 6', with 3.5mm to RCA ends for field use, and so I could connect my devices with 3.5mm audio ports to my A90/TA-20 desktop setup.
I'd been through a number of progressively more expensive series of pre-built cables for 3.5mm to RCA and they all failed to block RFI/EMI in my set up. Very disappointing actually, how poorly shielded cables are made today.
The
Worlds Best XLR/RCA cables built from Mogami 2534 with 4-wire quad-star faraday-cage-like shielding were the only ones I found out of a similar long hunt for RFI/EMI blocking cables that worked in my environment. So I asked WBC if they would build cables to spec using similar shielding design but modified to a light build for hand-held use.
If the 3.5mm-RCA custom built cables were built using
Mogami 2534 the cables would be unweildy in the field and in the hand (some are hand-held devices) with such a heavy thick cable, but Mogami makes a similarly shielded quad wire
Mogami 2893 which should fill the need nicely. I'm looking forward to testing the cable for RFI/EMI rejection.
I'll post my findings as I discover them. A word about my current state of health, it's not great, so I'm much slower to "get around to it" than usual, but I do persist - so eventually I'll post something, my apologies in advance for any delay's.
I've been working up to the custom 3.5mm to RCA cable testing for quite a long time, and it is nice that Topping released the HS01 USB Isolator I can test at the same time, coincidentally I have a number of deliveries scheduled to arrive this Thursday, 11/11 that were supposed to arrive later in November and December, it looks like some of the shipping blockages may be working themselves out for the Holidays, hopefully the HS01 won't take too long to get here.
My Kindle Paperwhite Signature Edition also arrives Thursday - and I am hoping, although I haven't seen it discussed or confirmed anywhere, that a USB-C to 3.5mm audio adapter will pass audio out the Kindle's USB-C port; then I can use one of the custom built WBC 3.5mm to RCA cables to play my Audiobooks EMI/RFI free through my A90/TA-20.
Now, perhaps someone will give the
Topping U90 a try and report on it here as well.
If there are any updates I'll add to this post later...
