2014F30
- Jan 31, 2017
I did not know that! Thank you! Should I get a 115v / 12v r-core transformer instead?
In speaking with someone that knows more than I do about electronics, I got the following regarding the 9v r-core transformer from ebay:
"That transformer has two 9V AC output windings. So you could either just use one of them, or place them in series to get 18V. Each output is only capable of delivering half of the rated wattage.
The regulator board appears to contain a full-wave bridge rectifier made up of four discrete diodes. So if you input 9V AC it should produce about 14V DC into the regulator, which should be more than enough for a regulated 9V DC output."
I tend to think it important...
Hi,
i´m interrested at the Topping D30.
Before i buy him i want to know if somebody has tested:
xmos stereo usb audio class2 driver 2009 v3.34.0.
Could i use this driver? Has anyone get him on run?
Sorry for my english
It seems to me like that in pursuit of the perceived last 5% of sound quality, it is where the high endarket thrives. It will be wasted on me as I recognize the limits of my hearing. Now if one is able to truly enjoy the pricey gear and is able to perceive a true improvement, AND, is able to comfortably afford to do so, I would be the first to applaud him/her. What strikes me as silly is when one acquires gear because of the need to "keep up with the Jones", and overextend his/her ability.
My happiness level lies exactly where I am presently, and I consider myself lucky for it.
Hi,
