Ali Express, Partsexpress,Amazon, massdrop. Just avoid eBay and auction sites I'd say.where's the best place to order this? I've heard there are fakes?
Wish I could help, but I run a MacBook Pro......Good evening,
Since I reinstalled Win7, I'm not able to make the DAC play via Firefox or Google Chrome or Expolrer browsers. It does play audio via Foobar2000 and VLC players, but not via the browser (for Youtube videos, etc).
Am I missing something?
Thank you all again.
I purchased a sh**ty Digione and it doesn’t work with either: the D30 and the Schiit Mimby.Hello,
Can I ask wich INPUT (usb or S/pdif)) on D30 is better implemented ? I'm deciding for a new transport - Allo Sparky Usbridge or Allo DigiOne.
So I'm wondering what's better on the D30 (USB or S/pdif).
regards,
Simon
Be sure that foobar2k is not outputting in WASAPI or ASIO. That would make it so that only foobar is using the DAC.Good evening,
That was the problem: in "playback" of System Sounds properties in Windows, the audio output was for "headphones", so all the browsers' content was playing via the built-in speakers of the laptop. Switched to Speakers Xmos and now it's fine.(...)
Also check windows default sound output
I am curious, in win 10, over USB the max output is 32/192. It was my understanding that the D30's max was 24/192. Is there a driver "confusion" with win10?
In some games occasional, not all current sound effects are rendered, as if there is "too much going on" to present all of the sounds. It may just be my motherboard or a software issue.
Yeah, I was noticing it in Terraria mostly. The game engine itself is old, I think my issue has nothing to do with the D30.I just checked and yeah Win 10 is playing 32/192 on Topping D30 without problems. I was curios and also tried 32/192 through a Foobar exclusive mode and again it works... I guess D30 is doing internal conversion from 32 to 24, but I don't see any purpose for doing this, it's not like there's much native 32-bit material anyway. I suppose the best thing is to keep it at DACs native 24. That said I never had any problems with games, movies... using it like that. In my system D30 is probably the best behaved DAC I ever used, never had any noise, loud pop etc.
