TOP IEMS IN CERTAIN PRICE BRACKETS.
Dec 26, 2012 at 8:48 PM Post #18 of 34
I very strongly disagree with the Etymotic MC5 recommendation, and slightly less so with the Shure 215 recommendation.
1. Nothing
2. Sennheiser CX300-II
3.MC5
4. HF5, Shure 215
Dec 27, 2012 at 5:33 AM Post #19 of 34
Third bracket the GR04 is very good and I think it sounds better than the hyped up MH1.  For the 5th bracket it has to be the Rockit R-50 and BA200, both have sound quality that's as good as IEM's $200 and up.  In the last one I's have to say the e-Q5/7 would be my choice there but if you can find the Earsonics SM2 for around $250 that's would be just as good I think.
Dec 27, 2012 at 5:44 AM Post #20 of 34
Ok. Here's the deal. Sometime in the next 3 months I will be purchasing tons of great iems for the sake of comparison and finally sticking to one.
The thing though is. I want to divide them in price brackets so I know which ones to treat anyhow and which ones to treat like a newborn babe.
I need up to 10 recommendations for the first 2 price brackets, 5 from the next two, and 3 from the others.
First bracket: $0-15
Second bracket: $16-45
Third bracket: $46-75
Fourth bracket:$76-99
Fifth bracket: $100-150
Sixth bracket: $151-250
Thanks for your help. I appreciate the input.
Don't expect the comparisons anytime soon. I'm just building a list for now.
And by the way, NONE must have any hint of harshness or sibilance. If they do, it should be very very minimal.
1. Phillips 3580
2. Vsonic Gr02 Bass Edition, Vsonic VC02(removable cables!), Sony Mh1c
3. Hifiman RE0
4. Ety HF5
5. Re-262, Rockit Sounds R-50
6. Gr07 MKII, Vsonic Gr01, Hifiman RE-272, Ety Er4P
Definitely Subscribed :D
Dec 27, 2012 at 7:19 AM Post #22 of 34
X2 for the Monoprice 8320 for the first bracket. Haven't heard any of them yet, but the Rock-It Sounds R-20 ($40), R-30 ($70) and R-50 ($120) all got value ratings of 10/10 in |joker|'s comparison thread, you might want to look into those.
Dec 27, 2012 at 11:25 AM Post #23 of 34
1. Phillips 3580
3. Hifiman RE0
4. Ety HF5
My list looks almost exactly like this
Only put Monoprice 8320 in tier 1  then it's good to go.
I'm sure you're one of analytical iems fan, phantompersona
Dec 29, 2012 at 12:13 AM Post #24 of 34
1. Monoprice 8320, JVC FX40
2. MH1C, Earpods (I'm dead serious), AT CKM50
3. Vsonic GR06, GR04, VC02 (not too sure about this one, haven't heard it yet).
4. Ety HF5 (depending where you look), JVC FXD80 (seriously overlooked)
5. EPH-100 (if you can look past the strange treble), EX600
6. GR07 MKII (I think you already have one), ASG-1.2 (with highs eq'ed up), Senn IE8 (not the IE80. That sounded grainy)
Good luck.
Dec 29, 2012 at 12:34 AM Post #25 of 34
One that I've seen a few have on they're list is the Dunu IC3-S and I really think that's a bad sounding IEM.  I trade an IEM that I got free for a pair and I'm glad I didn't have to pay for them because at around $100 new is way over priced imo.  The sound grainy and a bit muddy and lack clarity compared to other BA's in the same price range like the HF5 and A161p not to mention the R-50, I I'd stay away from those.
Any of the TWFK based IEM's are going to sound good and of the under $200 ones I think the R-50 and GR01 are the 2 best but I want to hear the Astrotec AX-7 which is around $135 from lendmeurears.
Dec 29, 2012 at 12:37 AM Post #26 of 34
If you traded for some that came from LendMeUrEars its possible you got shafted with a faulty product. There is a thread floating around about them right now and their warranty practices being shady.
The I3CS is a very clear IEM although not as clear as the Ety's. You have to remember the Ety's vs the I3CS are not after the same sound signature. The Ety's are meant to sound crystal clear and basically lack in everything else. They have no low end extension, where as the I3CS is almost the exact opposite and focuses on the lower end of the spectrum.
Dec 29, 2012 at 12:40 AM Post #27 of 34
1st bracket - soundmagic es 18/ sony mdr ex 60 lp( very detailed but harsh and sibilant)
2nd bracket - sony mh1c / apple ear pods
3rd bracket - not heard any
4th bracket - gh-erc-dms(best value)
5th bracket - ?
6th bracket - hifiman re 272!!!
Dec 29, 2012 at 1:04 AM Post #28 of 34
hmmm...
First bracket: Monoprice 8320, Philips SHE3590
Second bracket: VSonic GR99, JVC HA-FX40, Dunu Trident, VSonic GR02 Bass Edition, Astrotec AM-90, Rockit Sounds R-20
Third bracket: Fischer Eterna v1, Fischer Silver Bullet, Fischer Consonance, UE400/500, Vsonic GR06
Fourth bracket: Head-direct RE0, Shure SE215, Spider RealVoice
Fifth bracket: Etymotic Research HF5, Brainwavz B2, Rockit Sounds R-50, Fischer Tandem, Meelec A161p, Yamaha EPH-100, JVC HA-FXT90, Creative Aurvana Inear3
Sixth bracket: TDK BA200, Westone 2, Earsonics SM2, Vsonic GR07 MKII, Futuresonics MG7 Pro, Klipsch X10 (floats around fourth to sixth price bracket), VSonic GR01
Dec 29, 2012 at 1:25 AM Post #29 of 34
First: FX40
Second: MH1C, AF33, R1
Third: AF45, FXD70
Fourth: CKM500
Fifth: TDK IE800, TDK BA200, AF56, GR07, RE262, FXD80,
Sixth: FXZ100
Dec 29, 2012 at 1:31 AM Post #30 of 34
First: FX40
Third: AF45, FXD70
Fourth: CKM500
Sixth: FXZ100
Whats better the Audiofly AF56 or the IE800?  I know the AF78 really isn't very good at all but I don't know much about the AF56 dynamic driver.
