castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
@musical-shadow, I used body replacement technique on your post, so that it's in the proper topic.
you find a clear audible difference from that test, now the logic following is to try and find the reason. is it because they used 2 different masters? because of the formats? because of the 2 apps themselves or some setting in them? etc. depending on the actual cause the conclusions might not be the same.
