"...how good my audio gear was in terms of noise isolation and / or clarity..."
Can you fill us in in what that was?
I use a few. There's the Grado SR60i, Klipsch Reference X20i to name a couple.
For jogging, I'm using the Jaybird X2.
Then I'm not surprised with your comments. The differences do propagate out quite a bit with my HD800S, SR009 and Utopias. But looks like you've hit your sweet spot and saved some $.![]()
Absolutely! The SR60i is great value
Just wondering, are these the headphones (eg HD800S) you would bring when traveling on bus / trains? My context is that I'm on the move so portability is a big factor for me. How's the sound quality for Spotify / Tidal Hi Fi like in these conditions?
I didn't think there would be any difference (to me) between Spotify and Tidal HiFi, but I finally signed up for a 30 day Tidal trial to see for myself. Tidal is very very slightly more detailed, but it isn't worth double the price to me. I'm listening on a mojo and T90s. I'll keep listening and comparing during the free trial. If there's any music where I really want the tiny extra bit of quality I probably spend the money on a CD and rip it.
When I had tidal I always felt there was an EQ integrated into the sound. Not a ton but I definitely felt it was there.
who knows, maybe I was hearing more of my dac with my setup.
It depends on what your setup is. For the Mojo/T90, Spotify is just fine IME. But with my SR-009 setup, Tidal is clearly the way to go for me.
With a set up like that I would believe that the difference would be much clearer, and lossless would be a clear choice. I briefly listened to some classical music last night, and I believe that I could hear more of a difference. I just need to decide whether it's worth the money. I'll listen to Tidal a while longer and then switch back to Spotify and see how it sounds.
