The other big advantage of the bulkier, latest version of the CCK is that you can use the USB connection and charge the iOS device at the same time.
Tidal Lossless Streaming
- Thread starter Baroninkjet
Tidal Masters for all Android phones is now available for download. Check your setting to and make sure it is on.
Works on Android DAPs too. I have Opus #2 and loaded the new apk, I am getting the "M" tags.
Broquen
TheSnafu
- Feb 27, 2017
did some testing today when Tidal kept cutting off again and starts loading and again randomly stops play. also shows pink "server error" every now and then
problem:
song starts to play = hangs and keeps loading, no sound
Tidal app artists / playlists extremely slow loading
sound isn't distorted or bad, it just doesn't play
system
ASUS360 laptop WIN10 latest update, also latest from Tidal app (lap top works with every other app or streaming service)
cable connection 100/100mb (works with every other app or streaming service, netflix, skype etc, absolutely no problems)
laptop connected through wifi
laptop to:
-> DAC - Meridian Explorer 2 (latest drivers, works with every other app or streaming service, or devices like phone)
-> phone -> DAC
-> phone -> pre amp
->pre amplifier
same, just Tidal doesn't work
same system with
Netflix - no problems
Youtube - no problems
Skype, any streaming service - no problems
changing tidal or laptop sound settings doesn't make any difference
same happens with laptop & browser/netplayer tidal
Shortly, it is Tidal that doesn't work properly.
Any ideas (yes i have booted wifi and router and laptop and phone and.... changed cables)
problem:
system
laptop to:
-> phone -> DAC
-> phone -> pre amp
->pre amplifier
same system with
jazzfan
@TheSnafu, I feel your pain. I've occasionally experienced this issue. However, it never lasted for more than an hour or so. I'd suggest reporting this to Tidal whenever it occurs. Hopefully, can assist with real-time troubleshooting. Please report back if Tidal support resolves your issue.
TheSnafu
- Feb 27, 2017
found log of tidal and it says:
(Fri Jan 11 2019 14:40:12) [WARNING] - FLACDecoder::error_callback FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
(Fri Jan 11 2019 14:40:12) [WARNING] - Cannot parse metadata
(Fri Jan 11 2019 14:40:12) [TRACE] - Calculating next range to fetch...
(Fri Jan 11 2019 14:40:12) [TRACE] - Starting download...
(Fri Jan 11 2019 14:40:12) [TRACE] - URL: [ https://en-pr-ak.audio.tidal.com/v2/...957f17398581fe ]
(Fri Jan 11 2019 14:40:12) [TRACE] - Range: [ 5767168 , 6815743 ]
(Fri Jan 11 2019 14:40:13) [TRACE] - Size: [ 1048576 ]
(Fri Jan 11 2019 14:40:13) [TRACE] - Response status: [ 206 ]
(Fri Jan 11 2019 14:40:13) [TRACE] - Response message: [ Partial Content ]
(Fri Jan 11 2019 14:40:13) [TRACE] - Download time : [ 153 milliseconds ]
(Fri Jan 11 2019 14:40:13) [TRACE] - Downloaded byte size: [ 1048576 ]
(Fri Jan 11 2019 14:40:13) [WARNING] - FLACDecoder::error_callback FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
and this is where tidal hangs
any ideas ?
edit: looks like time lapse/song time bar and sound quality badge "master" are now brown instead of blue..
thanks
any ideas ?
thanks
Broquen
any ideas ?
thanks
Do you suffer this always with same songs? It seems that there're sync errors. Maybe the file is too big if you're streaming mqa files (brown ones). Try to test streaming same file in hi-fi. Maybe it will help
TheSnafu
- Feb 27, 2017
thanks for the reply but help how ? if i pay "masters/mqa" they better work...
hanging happens randomly (no certain song/album/artist), but when this hanging happens it lasts hours, then it works fine again.
i'm waiting tidals response. will report when they get back to me
Broquen
I always download songs and use streaming only from time to time (I'm traveling between Malta and Spain for work) and never suffered this issue. Looking at the log, it seems streaming problem, and if I'm not wrong (it can be perfectly possible that I'm wrong) it could be mitigated using music in offline mode or streaming music in less quality. Only throwing my first thoughts and ideas just in case it can help
TheSnafu
- Feb 27, 2017
ok, thanks. i stream only and problem was described a few posts earlier.
thanks for the input though, you never know how much it can help.
Got a 'fun' task for anyone that might have some time...I'm getting some weird distortion on Track 'First Trip' of of Herbie Hancock's album Speak Like A Child. Anyone else hear it?
BobSmith8901
- May 5, 2015
From which version? Masters or Hi Fi? Listening on one of the Masters versions, so far not hearing it. Can you describe it?Got a 'fun' task for anyone that might have some time...I'm getting some weird distortion on Track 'First Trip' of of Herbie Hancock's album Speak Like A Child. Anyone else hear it?
FiiO X5III thru Tidal v2.11 Android app
edit: Hey, wait a minute--on the masters version, both of them, first 40-50 secs I'm now hearing a sort of crumbly sound in the left channel. Is this it?
Lemme try the Hi Fi version--this 2004 remaster (Hi Fi) actually sounds better (more audible) than either master version and I do not hear the crumbly distortion sound in the first 50 secs or so.
edit2: It's there in the remaster but somebody really decreased it to almost inaudibility.
Could be something got in the audio stream somehow, possibly hardware related, during the original recording and the remaster decreased it quite a bit. It remains in the master versions for some reason. edit 5: I think the bass may be a bit hot in the original and this was causing some over saturation in the mic.
Edit3: I guess I have too much time on my hands! But wow, this is such a great record! The brass orchestration on the title cut is so beautiful!
yeah! Thats it! I am hearing the exact same thing. Wasn't sure if it was my playback hardware doing it so I wanted to confirm. LOVE this album and I appreciate your comments on the recording! cheers
BobSmith8901
- May 5, 2015
Yeah, Herbie's stuff from this period is incredible. I hadn't heard Speak Like A Child in many years. Maiden Voyage is another great one (among many!). This music is so good that you can listen to him on any type of music player (crappy or not) or format and enjoy it because the music is so engaging.
