With controversial topic you might mean that Jriver called Jplay a hoax ad refused to cooperate with them in the beginning...but IMO that statement was a hoax in itself. My suggestion is to try Jplay for free. You have a 30 day to evaluate. No strings attached. If you do not like it it is simply not for you...but then again you have at least tried it. :rolleyes:
I tried Jplay 6.2 after reading your posts. It is insane how much better my local library and Tidal lossless music sounds with BubbleDS Next and JPLAYStreamer. It took a while to get BubbleDS Next, JPLAYStreamer, and MinimServer working but it is worth it.
I didn't have an Android phone or tablet so on my control PC I downloaded VMware player (free for personal use) and Android x86 (open source project licensed under Apache Public License 2.0) 4.4 r2 VMware image from osboxes.org/android-x86
On the Android x86 4.4 r2 VMware image, I set the network card to bridged and installed BubbleDS Next app.
I also have Audiophile Optimizer and now I'm able to stream Tidal to my audio PC that is running in core mode and it sounds amazing. BubbleDS Next, JPLAYStreamer, MinimServer, and Audiophile Optimizer in core mode in my opinion are big improvements with the music like buying top of the line cables.
Next best value upgrades I've tried would be Shunyata Zitron Alpha analog power cord for a headphone amp and Zitron Alpha digital power cords for DAC, control and audio PCs. These power cords make the music sound fast with brilliant clarity and adds euphoria.
I am happy that my posts helped you to better sound!
It is an increadible upgrade in SQ with BubbleDS Next>JplayStreamer. If you get the Jplay setting and Asio driver settings right (ie. lower possible latency) you cannot stop toe tapping! In my case Fidelizer Pro 6.9 did an amazing results but guess that AO performs equally good. Heard several using both with good result though.
Reading about your amazing cables (love Shunyata cables but cannot afford them) I think you should have a closer look at UpTone Audio USB Regen http://uptoneaudio.com/products/usb-regen that the famous John Swenson is involved in. It is a powered USB hub that will bring your setup to the next level for sure...without costing a fortune. Possible to power by Linear PSU as well as battery PSU and improve things despite hifi grade USB cards. It is the next upgrade for me anyway!
