I will try to explain it as simple as possible.
JplayStreamer works in OpenHome/UPnP/DNLA standard and transform your computer to something similar to a Linn DS Streamer were your Android device is a control point. Your Android device works through the Wifi connection and your computer can still be connected to LAN since they communicate through the network...not through the wifi connection.
First the things you will need to get it working:
1. Computer with at least Windows 8 or preferly Windows 10 (I use W10)
2. DAC or USB>SPDIF converter with Asio driver (I use Stello U3 with TheSycon v1.61 driver connected to DAC)
3. Jplay 6.2
4. Android device
5. BubbleDS Next app
If you already have the correct computer and DAC your first step is to download Jplay 6.2 http://www.jplay.eu
Step 2= download BubbleDS Next to your Android device.
Step 3= select your DAC sound device as your default computer sound device and set it to 16-bit/44100 hz.
Step 4= open up the driver panel (In my case TheSycon driver panel) and set it initially to 128 and minimum latency. If you have no driver panel just go to the next step.
Step 5= open Jplat settings and select your Asio driver as device, Classic engine, DAC link 350 and PC buffer 0.5 sec. This is just to get it working. Best sound IMO is PC buffer 0.01 sec.
Step 6= open the BubbleDS Next app and select JplayStreamer under Local Media Server & select Tidal under Libarary>Cloud.
Step 7= Enjoy!
If you run into problem. Try to set Jplay Settings to higher values. When you find a value that works with your DAC you should note it down on a piece of paper and start checking other settings as well...for example KS, UltraStream, 1hz, 10 sec that many people like (not me though). If you still have problems set the driver in Windows 7 compabillity mode.
I do not have everything in front of me while I am writing this...but I think I got it all down.
Good luck!
Edit: Some additional info: When you start using the BubbleDS Next app you should play around a bit with the settings. There are many useful stuff there that is not used in the default settings. Also when you select the first Tidal track go to the playing window, press the three dots and select JplayStreamer as Linn DS player to get the album view. You will also see for example Lyrics there...but you will need to download the free MusicMatch app to get it working. The free BubbleDS Next works with 16 tracks at the time. If you buy the app you will get unlimited tracks in the playlist. If you have local files stored on OneDrive/GoogleDrive/DropBox etc you will be able to play them through BubbleDS Next/JplayStreamer as well...but this is not something that I have personally tried yet though.
It might seem all complicated...but it is really very straight forward. When you get it working it is as simple as turning on your computer, starting the app and play music. The Jplay settings is another story. If you want you can spend days fine tuning the sound for the better...but if you just get it working you will noticed a great improvement in SQ before you even started with better settings. A tip is also to buy the Fidelizer Pro 6.9 and set it to Network render and select to optimize JplayStreamer program as your Audiophile player. After you have done the settings it will start automaticly. It will add a considerable SQ improvement compared to the free version (that you need to launch manually)...especially with the Classic engine (which I now personally prefer to UltraStream in my current setup thanks to Fildelizer Pro 6.9)!
3. Jplay 6.2
4. Android device
Step 7= Enjoy!
Good luck!
