So I finally received my amp today!
Got it all setup very quickly, feeding it balanced via Yulong DA8 and using the NFB1-Amp as a Balanced Pre-Amp for my B22.
Build quality of the amp is the quality build I have come to expect from Audio-GD. very solid case with excellent fit and finish, smooth rads, great machining. smooth rotating volume control, nice blue display. Neutrik connectors, More inputs and outputs than I will ever use, What more could I ask for?
Right away I was scared ****less because the remote didnt work, but I opened it up and it had no batteries. Popped batteries in and it worked perfect. Note that is the smaller SA-31 remote on the right in the pictures. As you can see they have changed the design of the remote. The new design is nice, a little bit heavier due to its increase in size. I am going to be using this as my preamp in my 2-Channel Speaker setup in the near future so the remote is an extremely important feature to me. The remote feels very solid in the hands, and the build quality is top notch, it is machined of one solid piece of aluminum! I am a machinist by trade and I can tell it was made with a lot of care and attention to detail. It is not gonna break now matter how many times its dropped.
Note that each volume level change on the remote requires a click of the button. Holding the button down only ups the volume one level. (Ie. You have to press a ton of times to go up the whole volume range) A slight downfall but I can deal with it.
I had issues with my SA-31 Remote interfering with my Marantz receiver in the past, changing the volume on the Marantz in addition to the SA-31. Therefore I requested a different remote frequency to be programmed into my NFB-1AMP, but it looks like King-wa was kind enough to send me a whole extra remote board with my amp! I would assume that it has a second frequency to try if I have the interference issue again. Now that is customer service!
I love the return of the big silver volume knob! I have to say its my favorite part of the amp. I hate the buttons on my SA-31, takes way to long to adjust the volume through the whole range. With the rotary knob it only takes 3 seconds to adjust the whole range thanks to the exponential volume. The rotary knob is so nice and smooth, and you can feel each volume graduation step but not hear it from the knob. But you do hear the relays changing inside the amp, which I like personally.
One other thing I noticed, on my SA-31 when I turn it on, it flashes and gives me the option to restore the last volume level by hitting volume up. Unfortunately on the NFB-1AMP the volume is reset to 00 each time you turn it on. This means that in a speaker setup you have to hit the volume up button 30 times to get to a previous volume level of 30.
Listening on my LCD2v2’s right now and I love it so far! Very preliminary impressions but Sounds extremely detailed and balanced. Enjoy the pics.
