Carefully controlled comparisons are the best way to judge sound quality. (blind, level matched, direct A/B switched) Measurements are the best way to measure fidelity. We can measure everything we hear, but we can't hear everything we measure. So, past the point of transparency, it's pointless to spend more on measurable sound you can't hear. Some comparisons are advertisements too. Audiophile reviews are frequently nothing more than advertorial.
The big piece of advice that seems to never be mentioned in audiophile circles is ergonomics and usability. Convenience is MUCH more variable from one DAC or amp to another than sound quality. And comfort is of primary importance with headphones. It doesn't matter how good cans sound if they make your head hurt to wear them. I think reviews should spend more time on ergonomic issues than sound quality or fidelity.
I agree with most of this, bigshot.
But will add that I learned most of what I know about how headphones work and are measured from reviewers like Tyll Hertsens. And although we can measure everything we can hear, I think we still have a long way to go in understanding what alot of those measurements really mean, and how to best interpret them. And I think this is where the subjective impressions of different reviewers and users can also often be somewhat helpful.
Like you, I also wish that reviews spent a bit more time, and were a bit more critical on issues of fit, ergonomics, convenience, and also durability and construction. Some people are less sensitive to these things though. And there can also be a fair amount of variation in the way a pair of headphones, for example, can fit on different individuals as well, depending on the size and shape of their head. So what may be a good/comfortable fit for one reviewer may not be for another.
I probably pay more attention to a headphone's ergonomics, fit, comfort, durability and construction though than to most other factors. Though I'll also look at the FR, extension, distortion, driver symmetry and other sound quality characteristics as well. Because you can't really "fix" a headphone that has bad distortion. And there is also only so much correction that you can effectively do to a headphone's FR and symmetry, if those are also off.
I like hearing the reviewer's subjective impressions though as well, especially when they're compared to other headphones that I'm already familiar with... in addition to seeing all of the measurements.
These are the headphones that I've spent the most time with, and am probably most familiar with in terms of the sound, fit, and so forth, btw...
AKG K371 & K553 Pro
AudioTechnica M40x & M50x
Beats Solo 2 (wired version)
Beyerdynamic DT-770 (80 & 250 ohm)
Sennheiser HD 280 Pro & 380 Pro
All are closed over-ear headphones, except for the Beats which is on-ear. And the M40x and M50x, which are sort of in-between an on-ear and over-ear on my large ears. I don't currently use or own any IEMs or open over-ear headphones. Though I'm considering getting a pair of the latter.
