AmericanSpirit
Member of the Trade: Night Oblivion
Ear tip fit certainly was my challenges too, with bad fit, it sounded so thin. It took me a while trying on various settings and configs, ended up having to the genuine SpinFit cp100(the one comes is a mock up M-size), with iFi iEMatch 2.5mm(raises a bit on mid-base range) on line-out of dual AKM4497s. Works great with Monarch for my case!Okay. Now that I've had the Monarchs for a few days and had a lot of ear time with them, I know where they fit into my portfolio. The first thing I want to mention is that the first issue that I had with the Monarchs is gone. I attributed some initial incoherence, lack of bass and airiness to burn in. I am not so sure that is what it was because it cleared up so quickly. I must have had an ear tip fit problem. Now that I have adjusted to them, the fit is outstanding and the sound is fantastic even with the foam tips which usually aren't my favorite.
As I mentioned before, after addressing the initial issue, the dominant first impression I had was that the tuning is perfect. That is still true. I prefer the tuning of the Thieaudio Monarch's to all other IEMs I've heard to date. I A/B/C tested for tuning with the Sony IER-Z1R and Empire Ears Odin and on a Chord Hugo 2 running Tidal with no EQ and the FR I preferred most is the Monarchs. They nailed it for me. Then, I applied EQ. When I EQed the Monarchs to Harman, I much preferred the stock tuning of the Monarchs. So, I will be using the Monarchs as my own preference curve for IEMs and will attempt to create tuning profiles for my IEMs to this curve to see how it effects the sound. The only other time this has happened for me is with the Hifiman Ananda. The stock tuning for those headphones is better than Harman. I will be using the Ananda as my preference curve for full sized headphones.
Since frequency response is such a dominant attribute of sound, as I was initially listening across various music genre. I kept thinking to myself, are these my favorite IEMs? Do I like these more than I like the Odins? If it's true, I want to say it. So, I set out to prove that one way or another. It wasn't clear early on. It only became clear when I A/B tested the Monarchs vs. the Z1R and then vs the Odin across many tracks and playlists including Modern Pop, Jazz (bebop, bossa nova), Classical (symphony orchestra, violin concerto, piano concerto), classic rock. The bottom line is that I still prefer both the EQed Odin and Z1R over the Monarchs but only slightly which is amazing given the dramatic difference in price. As I mentioned, the Monarchs have the best tuning. But, they are not technically inferior. Not many IEMs can provide sufficient detail and resolution for Marriage of Figaro Sinfonia. The passages are so complex and dynamic that most headphones and IEMs can't deliver. The Monarchs do a very good job with it as I can hear the individual violins throughout the piece. The Z1R very easily have the best bass response. Texture, timbre and coherence is unbeatable. I always say that the Z1R is best for anything with a rhythm section (drum set, bass guitar, piano, electric guitar). The Odin has the best resolution, instrument separation and detail. The textures of the bass and mids are much more nuanced than with the Monarchs. The imaging is better with Odin. The best way to describe the superiority of the Odins in resolution when listening at low volumes. At 55-60 db, you can still hear all the detail from the sub bass to the airiness of the highs.
If I had to come up with a 2 word description of the Monarchs, I would call them the "Baby Odins." The tonal balance is perfect to my ear and I could listen to them all day long as they are not fatiguing. The clarity and transparency are present with all genres of music and they make great all arounders for me. Thieaudio knocked it out of the park with the product. The hype surrounding it is well deserved.
I happened to experience ear-gasm with goosebumps on Mussorgsky’s Pictures at an exhibition, baba yaga & great gate of kiev, a very extensive and dynamic chamber orchestral masterpiece.
Monarch certainly needs its burn-in time to settle.
