The qudelix has enough power to make the Excalibur sound like it should, especially if you connect it through the balanced port and set it to 4V.
In any case, with 2V it is already capable of bursting my Clairvoyance.
Well, unfortunately I don't have enough experience to suggest an appropriate amp.
What I can say for sure is that an iBasso DX300 can drive the Oracle (106 dB/mW) to full potential even at low gain. DX300 is rated at 7V max output (balanced) so you should look at something with similar specs.... apologies if this is not helping, but I'm sure Excalibur users will chime in with some suggestions
Had same issue with Oracle - the DD was shot on one side. On 1 month old set. Felt like one of the sides was not sealing right but that was faulty driver.
Same issue on my Clairvoyance, DD drivers are died after two months. Shipped to @Linsoul Audio, they returned and issue stills there. Very annoying situation.
May not be a bad idea if you are worried. But always keep in mind that those with problems with a product will always be more vocal than those without problems, so you may not get a good picture of quality by monitoring a thread like this.
I really wanted to like them but they took 10 weeks to ship in the first place then showed up with what I assume was a blown driver so I'm staying away from Thieaudio until they get it all the way together.
That's what I'm trying to avoid....wait for the time for them to be made PLUS shipping from China. So many things could go wrong, including "lost in transit". I'm not to confident making a gamble with almost $1k with so many negative things going around.
Yeah, and to be completely honest they were pretty bad about communicating reasons for the wait time, were dishonest about projected shipping times, etc. I can't recommend them at all after this one.
