Opus#2 Firmware Update 1.00.03 is HERE: http://www.audio-opus.com/?page_id=15757&uid=216&mod=document
All the same changes as in Opus#1, this is a minor update. Download was surprisingly fast over OTA.
The changes:
1. Added "Confirmation" message on selecting Line-Out.
2. Support auto turn off the function of Line-out ( Whenever user plug on/off 3.5 mm audio jack)
3. Support 2 Line display for long folder name(filename) in folder browser screen.
4. Fixed tag issue in m4a
So far, I haven't noticed any difference in sound quality, still at the top of its game!
Just flashed the .01 version yesterday! Did it via pc download, then USB transfer to Opus #2. Worked fine.
Did the same file transfer technique with the .03, then got the bright idea to also try the OTA version. Left the download trunning all night on my 2.4G wifi , showing strong connection, 26Mb speed. It was connected to my USB charger the whole time, while also playing a folder on repeat. The battery was at 100% this morning, the music was playing fine through my Nighthawks using high gain setting. Opus was not more than warm to the touch. But, the screen for OTA showed 18% complete, but the OTA file was the same size on the internal storage as the USB-transferred one, but was called 'partial ota pack...
So, I deleted both files, reconnected to USB, retransferred the Pack file, and it worked fine. I now am rockin' verion .03. I am trying to play it as much as possible, even if I'm not listening to it, to try to get some break-in hours on it. Liking what I am hearing so far, but the bass needs to fill in a bit more for my taste. It is an interesting contrast to my Lotoo and Questyle players.
More to follow.
