esn89
- Feb 11, 2012
this only means i need to plug the battery in differently, right? do i need to know any electrical engineering to install this?
is there a way to downgrade the software of opus using a pc? any tools to.use?
Hi thanks for the reply,Bonjour,
Tous les Daps Opus ont le même problème de batterie. J'ai fait changer la batterie de mon Opus1S, il y a deux ans chez "TheBit" en Corée, cela m'avait couté 50 euros.
Par contre actuellement ils ne répondent plus. Voici pourquoi je propose d'acheter la batterie sur Aliexpress et la monter soi même :
https://fr.aliexpress.com/item/4001327094823.html?spm=a2g0s.9042311.0.0.7d8f6c378thXlH
Si vous désirez quand même contacter "TheBit", voici leur adresse :
info@thebit.co.kr
TheBit co., Ltd.
Room no. 504, Yucheon Factopia, 30 Jeonpa-ro, Manan-gu,
Anyang-si, Gyeonggi-do, Republic of Korea (14086)
Tel : +8228620485 Attn : A/S manager
Cordialement.
Hello,
All Daps Opus have the same battery problem. I had the battery of my Opus1S changed, two years ago at "TheBit" in Korea, it cost me 50 euros.
However, they are no longer responding. Here is why I suggest to buy the battery on Aliexpress and assemble it yourself:
If you still want to contact "TheBit", here is their address:
info@thebit.co.kr
TheBit co., Ltd.
Cordially.
