mbwilson111
- Oct 13, 2016
Yeah, the older lithium batteries were designed to let it lower in charge and then charge back up. But that hasn't been the case since many many years ago. All Lithium-Ion and Lithium-Polymer (which are still technically Lithium-Ion, just with a thinner encasing to fit into smaller areas) need to stay at a high charge to keep their charge. They're like springs. When 100% charged they are fully squeezed-in. When you let that spring stretch out by losing charge, they lose their strength. Thus to help them last longer you want to keep them at a high charge at all times if possible, and above all else never leave them off at a low charge without charging them. This will kill the battery, and fast. I lost my FiiO X3 when it was dead, and when I found it a month or so later it would not even hold half the charge it used to. The first month the battery is in use is also critical to stay at high percentages, so if you're near an outlet then charge it.
There is much evidence and there are many studies on the internet that back this info. You can find it pretty easily. Everyone just tends to believe the rumor based on old batteries that you want to let the charge drop down to 20% or lower and then fully charge it again. This is incorrect and will slowly kill the battery.
Uh-oh
