Sorry not stacked together....i would be a bit careful pocketing with some optical cables as they can be very brittle and snap easily , the one in the picture that is the one that comes in mojo pack is very stiff and hard to find short ones ....but the combo sounds amazing.
I got them from a local seller. Non branded. I have another optical cable that came with my Mojo, that one is more thicker (upper right portion of the photo) - also Non branded - both gets the job done
Hi! If my music tags have a lot of extended tags will the Opus 1 have a tendency to crash or anything if I don't clean them up first with software like mp3tag? I would prefer not to have to do that if possible. I should also mention I have tried doing so a couple of times, but found it really tedious and difficult to figure out the process so I would really like to not have to do this if possible.
I have a question about my Opus 1.
I recently put in two 200gb cards. The music plays no problem, but I am now unable to get to the "settings" section. When I pull down to get to the jog wheel to appear on the screen on the upper right and press on it, it just cycles through to lyrics, or goes back to the song etc....
I have somehow lost the function to get to the settings section. This wasn't happening before. I am on the most current firmware.
The best case scenario is that the whole jog wheel area "blinks" but then....nothing.
Any idea of what to do? I tried powering it down and then restarting, but the problem persists. No reaction at all.
Grateful for any help. Am I doing something wrong?
Can't reinstall the firmware when you can't get to the settings. That must be the next step, but it is like the settings wheel doesn't exist. Very odd as everything else is working perfectly.
most likely your touchscreen is broken, i had exactly the same issues 2 months ago, unless i didn't change my microsd card, it just happened without any precaution
even worse, i can't access setting and library as well, it just like my touchscreen won't response at certain spot
i ended up sent them back to thebit via the store i bought opus at
